Bike Idle??
Old 07-17-2007, 05:41 AM
travis82's Avatar
Default Bike Idle??
I just bought my 500r last month. When i first start it it kind idles rough, not really bad just seems a little rough. But after i drive it to work, when i get there i let it just idle and it smooth as ****. Does it just take the bike awhile to warm up? Is there a certain length of time i should let my bike run before itake off???
Travis
Old 07-17-2007, 01:20 PM
calamarichris's Avatar
Default RE: Bike Idle??
No! It's really best for your bike if you minimize use of the choke and ride it very gently for the first two miles.
I pull my hair outta my head when someone says, "Ya gotta let these things warm up for at least five minutes with the choke."
That not only fouls the plugs, it also fouls/rinses away the oil film on your cylinder walls, which causes premature wear on your tender piston rings and eventually, premature loss of compression.
Start the bike, using just enough choke to keep the bike alive (~1500-1900 rpm), while you put on your helmet & gloves, then ride slowly, gently away, turning the choke off as early as you can. Then keep it below 4,000 rpm for the first mile or so and your throttle inputs gentle.
Good luck and ride safely.
Peace!
-CCinC
Old 07-18-2007, 06:39 AM
travis82's Avatar
Cool thanks mand i appreciate the info
preload
05-24-2021 02:58 AM
povo
07-13-2008 07:11 AM
123FU
05-28-2008 01:37 PM
Professor`
04-26-2008 01:45 AM
col_klink10
07-27-2007 03:01 PM
Quick Reply: Bike Idle??
