Top speed ?
I am 6'1" and about 190 lbs. and I just got my ninja 250 2007 up to 115mph at 12.5k rpm. I had it full throttle but it was slowly climbing. I might have been able to squeeze 120 out of it and this was on a straight away.
None of these reported speeds reallymean anything ....the stock speedo's are off as much as 10%..
You need an onboardGPS unit to give you a reliable top speed.....which will be around 100-103 ,IMHO,depending on about ten different factors...air density,wind,tire pressure,pavement,temperature,rider weight,body profile,chain tension,etc,etc
Thanks eastender43, but I think a good stock to stock even if 10% is worth a report or at least a baseline.
Ok,I'll buy that,but HAWKK originallyasked"What is the ACTUAL top speed of a 04-05 EX 250?"
The key word being "ACTUAL"....not indicated,fabricated,matriculated,interpolated,cal culated,or extrapolated....but ACTUAL....for which you need an onboard GPS,or perhaps VASCAR,RADAR,LASER,courtesy your favorite LEO>>>
