Small hands and hand levers
Old Nov 8, 2006 | 04:56 AM
LeftyS7's Avatar
Default Small hands and hand levers
O.K., the Ninja 250 I've been riding is my wife's. She was away on vacation and I got to ride it, now she's started to, and the bike fits her well BUT for the reach to the brake and clutch levers, a real (and painful) stretch for her. What have you riders with small hands done about this?
Old Nov 8, 2006 | 05:04 AM
kawasakifan700's Avatar
Default RE: Small hands and hand levers
Get a shorty clutch lever. I think that should help.
Old Nov 8, 2006 | 06:35 AM
evil636's Avatar
Knee Dragging Pimp
buy longer gloves. lol. do the 250's have a reach adjustment ? like on the outer front part of the brake lever there is a screw you can turn that will adjust the lever from the bar ? or you can look into a aftermarket assembly too. just an idea. do the levers have a dial on them marked 1 2 3 4 ?
Old Nov 8, 2006 | 07:29 AM
file down the fulcrum point on the lever. Just not too far. She needs brakes too! lol
Old Nov 8, 2006 | 10:20 AM
suprakawigrl's Avatar
Pazzo and CRG levers both have 6 adjustment settings on top of the fact that they swwop in closer to the grips. I have the Pazzos on my ZX7R and I leave them at "1" being the closest setting. These levers definitely make riding more comfortable.
Old Nov 9, 2006 | 03:31 AM
LeftyS7's Avatar
Thanks for the suggestions BUT neither Pazzo nor CRG lists a lever for the Ninja 250. Anybody actually made mods or installed aftermarket levers? What brand and part number?
Old Nov 9, 2006 | 07:27 AM
Actually I do not have part numbers on your ride.
I use the cheap plastic '87 and '88 levers on my '90 zx7 and modify the fulcrum. Track use and I tend to fall down every once in a while.
Old Nov 19, 2006 | 04:05 AM
ZX12Rider's Avatar
I'm surprised they wouldn't have adjustable levers on the 250. They have them on the 500 (which is a good thing otherwise I'd be screwed!) I wonder if you'd be able to get something off the 500 and use it on the 250.....
Old Nov 19, 2006 | 05:58 AM
mnosbor's Avatar
The EX 500 levers work but you have to replace the perch as well. If I remember right you can bolt on the perches but have to cut off the old perches if you want to avoid having to remove other parts.
I have very small hands and wear childrens size gloves. I have not bothered with replacing the levers. I just made sure the clutch was adjusted properly and worked on strengethening my hands. I did get some hassle in MSF because I drop my index finger off the brake lever when I showed them I cant reach it with that finger they cut me some slack.
Old Nov 19, 2006 | 08:44 AM
As mentioned by bb
I would have thought that the two would share some parts. Why my posting on the 88-90 zx7's earlier and swapping parts.
Ginsu4u
Dec 15, 2006 06:27 PM
MAD KAW
Aug 7, 2006 03:12 AM
xrider
Jul 20, 2006 04:35 PM
walight01
Feb 18, 2006 07:41 AM
onewheel
May 12, 2005 04:33 PM
