RETORFIT HEADLIGHT
Old Jul 4, 2007 | 08:14 AM
batang city jail's Avatar
Default RETORFIT HEADLIGHT
ok.. anybody is interested on a retrofitted headlight? its still in developing... pics will be posted if the headlight is done.
Old Jul 4, 2007 | 08:35 AM
markmeinteil's Avatar
Default RE: RETORFIT HEADLIGHT
Will you be using a different upper fairing to fit this headlight? If the shape of this retrofit headlight brings the 250's appearance up to date, I'm sure a lot of people would be very interested.
Old Jul 4, 2007 | 05:20 PM
mnosbor's Avatar
Id be interested, just keep in mind that the electrical system only has about 55w to spare if you are adding bulbs.
Old Jul 5, 2007 | 02:07 AM
ORIGINAL: markmeinteil
no, the head light will be the same in shape,but the lense will be sanded to be cleard, were trying to fab a plastic though.. as far as of now,. a custom bracket will be needed just incase..
Old Jul 5, 2007 | 02:09 AM
ORIGINAL: mnosbor
somewhat, thats the problem since its DRL, but we are doing HID/projectors
Old Jul 5, 2007 | 06:24 AM
fms1day's Avatar
i've retro'ed HIDs on my ex250.. just make sure the plug ti the bulb and the projector fitment is good. mine hit the frame....
Old Jul 13, 2007 | 08:07 PM
striker_1818's Avatar
ahh as I was looking for headlights for batang's retrofit,I came accross this site.
I'll be doing the retrofit with a bixenon G35 projector...I'll swap lenses with the e30 for a sharp cutoff, blue colorband and more output(wider).
I just purchased some headlights and will be using murano shrouds.
Method:
- I will be sanding out the headlights to make them clear.
- fitment will require modification
- The projector must be as close as possible to the outside lense of the headlight housing so there will be more light and have greater foreground limiter.
- custom murano shrouds will be used for a unique look
- This will be my first bike retrofit lol
Old Jul 20, 2007 | 04:34 AM
^^ thanks 4 chiming in buddy... ^^ he is the guy who is going to do a retro fit..
Old Jul 21, 2007 | 05:02 AM
fms1day's Avatar
ORIGINAL: striker_1818
Method:
If you don't take into account of the projector's fitment in the housing and how much it will stick out of the housing... you will encounter problems when mounting them onto the bike because if the projector sticks too far out the housing, it'll hit the frame... if not the projector, the ballast plug may or will not fit because of the frame.
Good luck
Old Jul 26, 2007 | 08:58 AM
So, any updates? Pics?
