Need Help, Please!!!!
Old Jun 26, 2007 | 12:08 AM
amybeth4's Avatar
Default Need Help, Please!!!!
I have a 2002 250. It hasn't been ridden in quite some time andam getting it ready to sell. When the bike was parked it ran fine. Since we made the decision to sell we have changed the battery,drained the fuel and pulled the carbs and cleaned the mainjets.It starts and idles fine but will not take any throttle at all.Any suggestions on where the blockage could be or what else to check? We sprayed cleaner into the throat of the carb and it took throttle and revs, it seems that the carb is starved for gas.
Old Jun 26, 2007 | 02:05 AM
mnosbor's Avatar
Default RE: Need Help, Please!!!!
You need to take apiece of copper wireto all 4 jets, make sure the floats arent sticking and run spray cleaner through all the orifices making sure cleaner comes out all of them. You plug off someopeningshere and there until you are able to get it to flow out of each small opening. Also clean the pin holes on the sides of the carb throats. Theres some idlerelated partsyou can clean but since it seems to idle fine dont bother it. But if you want to make sure remove the idle mixture screws (you have to remove the epa caps)and clean the orifices and make sure you put them back together correctly. Turn them in all the way then back out 2 1/2 turns.
Youll also want to make sure your diaphrams arent damaged, dried outor stuck, Ive had the plastic slides get sticky. They move up and down by vacuum so its important they are moving well.
Are your vacuum lines routed correctly?
When they dont run right its usually the carbs, its likely you missed something. Old gas turns into shellac so getting it out of the orifices can be time consuming. Also make sure you have fresh gas in the tank not something thats been sitting for the lawnmower for a couple of weeks.
Ninjaattack
Mar 23, 2010 04:44 AM
WestOzKLX
Apr 21, 2008 07:23 PM
fredhill032188
Jul 24, 2007 10:47 PM
86ninja600rider
Dec 8, 2005 05:07 AM
