Install LED signals without using resistors
Old Jun 22, 2008 | 09:39 PM
randomwalk101's Avatar
Default Install LED signals without using resistors
The problem: When installing any LEDs signal in place of stock, the signal lights will stay on solid.
Half fix: Install an aftermarket ELECTRONIC flasher in place of stock (mechanical) flash will fix this problem. However, it will only work if you only swap out 2 stock signals with LEDs. If you swap out all four, all of the signal will flash (like harzard signal in a car) rather than left or right signaling.
Adding resistors: With all four signal swapped out, you can add resistors to increase the load to fool the system. However, if you forget to cancel out the signal, the resistor HOT. It'll get hot...too hot to the touch. Not good whereever it sits...It can melt plastics, wires etc. that it touches.
Solution: Adding diodes kit to the signal system.
You need to swap out your mechanical flasher relay to that of the aftermarket ones like CustomDynamics, CustomLED, or find a cheap one $4 electronic flasher at your AutoZone will work. After swapping out the flasher, install your favorite LED signals at all four corners of your bike. If you turn on the signal now, ALL signal will flash...I believe the tail light also flashes.
Then you need to make a diode kit. Basically just attaching the two diodes together & solder and shrinkwrap them (see attached pics) then add it to the bulb socket under your speedometer. The diodes should prevent the back feed of the system making everything flashes...your LED signals now should work like normal. To prevent this backfeed, you add the diode kit as below.
1) Make the diode kits...See pictures. Any 12volts diode will work
2) Twist/remove the signal indicator socket off the speedo. cluster (should have 2 wires attaching to bulb).
3) Cut these two wires.
4) Attach the two wires coming off diode kit (on opposite side of the marking on the diodes) to the cut wire on the bike's harness.
5) Attach the single wire on the diode (on the same side as the top marking of the diode) to one of the cut wire off the bulb.
6) Attach the other wire off the bulb (the only remaining wire) to the bike chasis (ground).
7) Put bulb/socket back into the speedometer cluster...
Credits: Ideas & Instructions were given to me by Todd at Custom Dynamics.
Disclaimer: If you cross wires or ****up somehow and ruin your bike, I am not taking any responsibility for your action...
http://i241.photobucket.com/albums/ff11/randomwalk101/Diodeindicatorplacementdrawling.jpg[/IMG]
http://i241.photobucket.com/albums/f...k101/pic01.jpg
http://i241.photobucket.com/albums/f...k101/pic02.jpg
http://i241.photobucket.com/albums/f...k101/pic03.jpg
http://i241.photobucket.com/albums/f...k101/pic04.jpg
http://i241.photobucket.com/albums/f...k101/pic05.jpg
http://i241.photobucket.com/albums/f...k101/pic06.jpg
Old Jun 23, 2008 | 12:40 AM
markmeinteil's Avatar
Default RE: Install LED signals without using resistors
Hey, great writeup.[8D]
Old Jul 20, 2012 | 06:19 AM
Prdan420's Avatar
i used 10 watt 10 ohm resistors and bought nylon heat resisting cloth to prevent any damage everthing works fine i am only using two resistors for 6 led lights two in my headlight two led blinkers on forks and rear of the bike Good luck .
Old Jul 20, 2012 | 03:28 PM
Pictures go to page not found
Old May 25, 2013 | 03:00 AM
oregon_gutter_rider's Avatar
So you're saying you need resistors and the electronic relay and a diode, right... maybe that's my problem. I hadn't quite gotten the diode thing, but you explained it. This could be why I keep blowing my 10 Amp fuse for the flasher circuit, eh. I was running an electronic flasher, LEDs for blinkers, but I thought I could leave off the resistors because of the electronic flasher. You're saying I need the flasher, resistors and a diode, right...
2k1w=no$
Mar 20, 2010 04:58 PM
afboundguy
Aug 12, 2007 05:50 AM
brnr17
Apr 6, 2007 08:01 PM
my green kaw
Aug 15, 2005 06:55 AM
raychizel
Jun 27, 2005 12:27 AM
