HELP!!! I THINK I BLOW A FUSE
Old Mar 28, 2006 | 04:53 AM
jimmys250R's Avatar
Default HELP!!! I THINK I BLOW A FUSE
Ok, I went home last weekend and saw a few guys taking their sport bike out and I try to take mine out too.
I stored the battery inside my house since October without charging it and it wouldn't start my bike after
hooking it up. I know I must be stupid enough to use the car battery to jump my bike battery. Anyways,
there was a spark the first time and I take it off immediately. I should stop and THINK but I insist and tried
the second time. This time, my sister's boyfriend helped me hook it up to the car and let it for about five
seconds. Smokes start to come from the battery and I told him to take it off quick. The jumper wire was
HOT.
I then use my brain and call Advance Auto to check if they charge battery and they said they do. I took the
battery to them to recharged and reinstalled once it's finished. Still nothing lighted up. I got worried. That
day, on my way back to my work home, I called one of my friend who is a mechanic that also owns a
Hardley Davidson bike. He said I probably blow a fuse. I felt a little relief but am wondering if any of you
guys had the same problem.
Any input is greatly appreciated. Thanks!
Old Mar 28, 2006 | 04:56 AM
Mr. Toad's Avatar
Default RE: HELP!!! I THINK I BLOW A FUSE
You didn't jump the bike with the car engine running did you? [&o]
The car charge while running would be too much for the bike to handle.
Old Mar 28, 2006 | 05:01 AM
evil636's Avatar
Knee Dragging Pimp
same question as toad, i jumped a few bikes with a car battery and never had a problem.
Old Mar 28, 2006 | 05:11 AM
Notstock's Avatar
I too have used a car to jump my bike with no problems. Sounds like you may have crossed the jumper by mistake. Follow the red or hot wire off your battery to find the main fuse and check it. Also, check the smaller fuses and make sure they are okay.
Let us know what you find.
Old Apr 4, 2006 | 11:41 PM
jimmys250R's Avatar
Well I haven't gone home yet so I will check it this weekend and hopefully it's only the fuse that
is blown. As for the battery jump, the car was OFF before I jumped the motorcycle battery. I am
not sure if I should ground end of the car's battery to a metal on the car but I connect positive
to positive and negative to negative of both batteries.
Old Apr 4, 2006 | 11:54 PM
Notstock's Avatar
Do you have a multi meter so you can check voltage off your battery.
Corey John Schweikert
ER 6N
Feb 6, 2013 12:03 AM
tonhgpz
Dec 24, 2011 02:22 AM
Worlok14
Dec 22, 2010 02:40 PM
deej
May 26, 2006 04:46 AM
ArataOGK
Jun 20, 2005 08:57 PM
