Help, Engine Question
Old Apr 20, 2006 | 10:44 PM
gsims's Avatar
Default Help, Engine Question
My girlfriend just bought a used 2004 250 as a starter. It starts fine and runs with throttle; however, without throttle it dies. I tried adjusting the idle and noticed that the RPMs drop about every 15 seconds or so. My gut is telling valve/timing problem......????
Old Apr 21, 2006 | 03:01 AM
MAD KAW's Avatar
Default RE: Help, Engine Question
even after you adjust the idle it dies huh?.... i would say it's timing.... did you buy it from the stealership like that? or was it a private party....
Old Apr 21, 2006 | 07:15 PM
gsims's Avatar
After raising the idle considerably (about 3500 RPM), it didn't die, but it followed the same pattern: correct RPM for a few seconds, then drops for a few seconds, then back up to where it should be, rinse, repeat. I noticed it on the road with higher RPMs too.
Bought it private party. The bike was a deal ($1200).....well, uh almost..... the first owner laid it over on a shoulder at low speed - usual scratches on the fairing & replaced blinker, no damage behind the plastic (gf wanted something she could drop in the parking lot a few times and not worry about as she's learning). Clean other than that. Hopefully, it won't be too expensive....
I'm guessing you're right about the timing....or perhaps the carbs???
Old Apr 21, 2006 | 10:19 PM
Notstock's Avatar
I would take off the carbs and clean. Do not forget to remove the pilot jets and make sure they are spotless; they are the ones that control idle and slow speed.
After that if the problem persist vale adjust may be due.
Old Apr 22, 2006 | 03:26 AM
BigRig18Wheeler's Avatar
I had a bike that did that once...ended up being a vaccuum leak from a split hose under the tank..... caused the exact same prob.
Old Apr 22, 2006 | 04:04 AM
Notstock's Avatar
ORIGINAL: BigRig18Wheeler
Good point, I always forget about those stupid hoses
boarders09
May 13, 2020 03:06 AM
TomCinn
Nov 27, 2013 06:41 PM
Israel-klx250s
Mar 4, 2012 08:33 AM
amck
KX125
Jan 17, 2011 05:20 PM
dbblo
Dec 17, 2005 07:32 PM
