Edit: (STARTED)
Old Oct 21, 2007 | 07:07 PM
  #61
Mott Power's Avatar
Default RE: Still not starting
Yeah, had a coolant leak, it was from the small pipe that goes into the cylinder head and to the thermostat, isn't leaking now. And the smoke was from the exhaust wrap, seems like it has to cure a bit to the headers.
But oh my god.... it's twice as loud as it used to be and is so much faster... I'm so happy!!!!!!!!! My compression is REAL good and there is a lot of power down low. Quick question, it's idling kind of high though, idle fuel mixture screws are 2.5 out, I'm guessing if I turned them in it wouldn't idle as high?
... it's a completely different bike...
Old Oct 21, 2007 | 07:22 PM
  #62
Turn the idle ****, not the a/f screws. At least all of the ninja's that I have had the **** on the left side of the ride.
Sounds like good progress. Congrats and enjoy.
Old Oct 21, 2007 | 07:35 PM
  #63
Mott Power's Avatar
Well thanks again for your help man, I really appreciate it.
Old Oct 21, 2007 | 09:48 PM
  #64
Prom's Avatar
Woooohoooo! Congrats Mott.
But you gotta say what it was, so others wont make the same mistake....namely me
Old Oct 21, 2007 | 11:16 PM
  #65
Mott Power's Avatar
hehe, i don't think anyone could make this mistake... it was bad.... like as in, i am stupid
camshafts were switched [&:]so everything was 45 degrees off, which is why half of it was intake and the other half was blowback (piston on compression cycle while the valves were still open)
Old Oct 21, 2007 | 11:38 PM
  #66
yoman1's Avatar
Congrats man, crap happens,I'm glad you stayed with it, a lot of guys would have taken it to the shop in a box.
Old Oct 22, 2007 | 03:04 AM
  #67
Mott Power's Avatar
Thanks man, I had gone too far to go to a shop at that point, glad I didn't... [&:]
Still idling high though, I'm gunna try to adjust my throttle cables but I dunno, I turned my idle screws in one full turn and didn't make too much of a difference, could it be the main jets?
Old Oct 22, 2007 | 03:52 AM
  #68
[sm=chairshot.gif] hahahaha
camshafts were switched [&:]so everything was 45 degrees off, which is why half of it was intake and the other half was blowback (piston on compression cycle while the valves were still open) [align=right]
[/align]
Old Oct 22, 2007 | 03:59 PM
  #69
Prom's Avatar
I coulda made that mistake, as for setting the idle, you know more about it than I do
Old Oct 22, 2007 | 05:23 PM
  #70
korax123's Avatar
Congrats on getting the bike started and running good.
I would check for a vacum leak for your High Idle the wrong amount of fuel wouldn't make it idle any different.
