E85 in the bike
Old Sep 10, 2007 | 04:32 AM
dustin_dodson's Avatar
Default E85 in the bike
I want to try a 50/50 mix of e85 and gas what do you guys think?
Old Sep 10, 2007 | 01:51 PM
ninjan00b's Avatar
Default RE: E85 in the bike
im not that knowledgable of a human, but i think that that is a bad idea. e85 has alcohol and that wears down rubber a lot faster that convetial gasoline and is just hard on the engine, so unless youve modded your internals it might not do you to good. what are you trying to get out of putting e85 and gas in your engine. you are already getting high mpg?
Old Sep 10, 2007 | 03:29 PM
dilysi's Avatar
you will louse power ethanol bearns colder thea regular fule there wount be as much power
Old Sep 10, 2007 | 04:18 PM
CaddyDaddy's Avatar
Without rejetting the carbs, it won't work very good, and will probably ruin the fuel system. E85 engines require more fuel to run, so your engine will be running lean at best, and probably do some damage from pre-ignition.
Old Sep 10, 2007 | 07:39 PM
JaBr1884's Avatar
Hope you checked the responses before going with it
superninja600
Jul 6, 2008 10:07 PM
jeffzx9
Dec 25, 2007 12:37 AM
shox rox ice
May 29, 2007 08:03 PM
