changig headlight HELP
You dont need to remove the windshield. Also there are 2 phillips screws under the front of the faring below the light...dont remove those either.
And you dont need to remove the headlight housing.
Also be very very careful, some 250s came with the wrong faring bolts. They will puncture the tank if you put the wrong ones where the tank is. Take them out label them then see if theyre all the same length if they are then your fine if not then be very careful and dont mix them up.
There was a recall on the 07s for this reason but it has been reported to affect other model years.
ORIGINAL: mnosbor
Thad-deus Coan
Sep 14, 2012 04:32 PM
Thad-deus Coan
Ninja 250R
Sep 13, 2012 06:11 AM
