250 1st gear question
Old Jun 9, 2007 | 01:43 AM
jj06's Avatar
Default 250 1st gear question
hello, im taking a msf course and the bikes were using are 125s, and we can get the bikes moving with releasing the clutch slowly and not use any throttle at all.. my question is can the ninja 250 do the same? does the idle have to be raised to do this?
Old Jun 9, 2007 | 02:22 AM
markmeinteil's Avatar
Default RE: 250 1st gear question
Yes, it will.
Generally, the larger the engine displacement, the more low-end torque the engine has to move the bike forward without opening the throttle.
Old Jun 9, 2007 | 06:11 AM
mnosbor's Avatar
If the idle on the 250 is set correctly you will have to apply some throttle,the idleshould be between 1200-1500 rpms. The 125 has a different carb set up and may be running richer.
H. Vince
Apr 11, 2012 04:45 AM
sh3llycakez
Apr 2, 2008 11:57 PM
osufireman
500 LTD
Mar 11, 2008 02:35 PM
Icantrideabike
Jun 28, 2006 06:57 PM
