Help!
Old Mar 25, 2007 | 08:54 PM
davehayward1's Avatar
Default Help!
I messed with the "idle adjusting screw" (a black **** located behind the carbs)
and the bike either won't start or revs so high I have to shut it down
Sometimes it'll idle too high and then rev itself way down to the point where it stalls out
I can't find a "set point"
Any suggestions?
Old Mar 25, 2007 | 09:01 PM
Default RE: Help!
I messed with the "idle adjusting screw" located behind the carbs
(a black plastic **** you turn with your fingers)
Now I can't get the bike to start
It'll rev way too high so I have to shut it down, or it won't start at all!
I can't find the "set point"
Old Mar 26, 2007 | 12:22 AM
Default RE: Help!
Welcome to the forums davehayward1
Did the ride run properly before you messed with it?
Old Mar 26, 2007 | 08:18 AM
markmeinteil's Avatar
Default RE: Help!
You just have to mess with it while the bike is warmed up and running with the choke off. It shouldn't make your idle go crazy like you say it does.
82ltd
Aug 26, 2006 06:02 PM
