changing fork oil
Old 04-23-2007, 12:29 AM
joepa's Avatar
Default changing fork oil
Hi all, my dad has a Vulcan 500 and wants me to change his fork oil after I did mine on my 750. However, looking at the forks I don't see any obvious bleed valves. Is it located above the axle that passes through the bottom of the fork? Thanks.
Jeff
Old 04-23-2007, 12:33 AM
Default RE: changing fork oil
Look in the manual or even the fiche for that model. I cannot give you a definite answer.
Welcome to the forums.
Old 04-23-2007, 01:35 AM
joepa's Avatar
His owners manual states nothing about them except in themaintenace chart and that it is a "dealer" performed service.
Old 04-23-2007, 02:56 AM
For example in my factory service manual on the 10r, the leg has to be removed in order to change the oil.
Old 04-23-2007, 10:33 AM
markmeinteil's Avatar
The "owners manual" will not likely have any info on changing the fork oil. You need either an aftermarket service manual, or the factory service manual. As dragone said, you could go to Kawasaki's website, or www.bikebandit.com and look at their parts micro fiche diagrams to get an idea where the drain hole may be.
daren1093251
KX85
01-03-2014 10:37 AM
MJohnson
Ninja ZX-9R
03-20-2011 03:17 AM
joe sprocket
04-03-2008 12:25 AM
alexanderm
07-15-2007 01:18 AM
06black636
02-05-2006 02:01 AM
Quick Reply: changing fork oil
