2012 kawasaki mule turns over but wont start
Bought 2012 mule not running. Twin cylinder. Was told it needed crank position sensor not so sure I have ohm tested at 125 ohms which I believe is in range. It has NO spark,there is gas in the tank,previous owners has changed fuel pump but didn’t do anything. I have a new cps but I don’t think it’s the problem, both coil packs have power to them. I have power in a white wire which is going into what I believe is the ecm under the dashboard. At the moment I’m out of ideas next will be remove flywheel cover and check magneto,and stator also have checked 3 wire plug from stator all 3 wires ohm at 3. I need help
