2005 Brute Force 750i
Please help, just bought this ATV and I have problems. 2WD/4WD flashing about 2 seconds. Repair manual states to check the brake actuator. It does test bad. At the same time I tested my 4WD actuator and it tests bad as well!! Could they both have gone bad at the same time? Also the manual says if both are bad my 2WD/4WD lights should be flashing about 4 seconds apart? Dosn't make sense. Dealer is of little help only wants me to bring it in. Other components in system check out OK.
RE: 2005 Brute Force 750i
I would try replacing the brake actuator first. It could be triggering the 4X error code as well. Just a thought. Try disconnecting them one at a time and see what happens to the error code. Shouldn't hurt anything.
PS, welcome to the forum. |
Welcome to KF. You have verified the troubleshoot in accordance to your manual. Good luck and again welcome.
Welcome to KF, I would just take it in and let them fix it if under warranty. Just my opinion.
welcome to KF.
welcome to KF yeah I would just take it to the dealer but do one at a time first if your gonna do it yourself
