Low-compression piston on 08 KX250F
Old 11-23-2023, 02:35 PM
Zniper's Avatar
Default Low-compression piston on 08 KX250F
Hi guys, I just have mine 08 rebuilt with the 04-05 KX250F piston (by Wiseco) installed, which has 13.1:1 ratio. Valve timing, clearances, spark... look good.
However it seems much harder to start. I could make it firing up only few times since, whenever it starts, the engine sounds normal and smooth.
Do you have any experience on using that old model piston? And could that lower ratio 13.1:1 be the problem on starting issue?
Thanks in advance.
Old 11-27-2023, 03:18 AM
Zniper's Avatar
Updated: my KX new top end seems good to go. The new combination needs more time to really breakin and now after 2 hours, it starts easier and everything works properly.
pickup76
08-11-2018 09:34 AM
Tre Breeden
KX250 & KX250F
02-18-2018 03:59 PM
Craig Gast
KX250 & KX250F
07-06-2017 01:37 AM
Ronnie829
11-28-2016 05:34 AM
OMalley912
KX250 & KX250F
04-08-2008 01:12 AM
Quick Reply: Low-compression piston on 08 KX250F
