Low-compression piston on 08 KX250F
Hi guys, I just have mine 08 rebuilt with the 04-05 KX250F piston (by Wiseco) installed, which has 13.1:1 ratio. Valve timing, clearances, spark... look good.
However it seems much harder to start. I could make it firing up only few times since, whenever it starts, the engine sounds normal and smooth.
Do you have any experience on using that old model piston? And could that lower ratio 13.1:1 be the problem on starting issue?
Thanks in advance.
Thanks in advance.
pickup76
Aug 11, 2018 09:34 AM
