impeller question: 86 kx 250
Old Jun 20, 2012 | 06:22 PM
dykaar's Avatar
Default impeller question: 86 kx 250
On my first ride, I noticed the rads were cold. Bad sign. Removing the impeller cover, I see the impeller has a big crack and is loose on the shaft.
When I try and remove the nut, the shaft spins. Really bad sign.
I'm missing a drive gear, aren't I? Feh.
Attached Thumbnails impeller question: 86 kx 250-impeller-wheel.jpg
Old Jun 20, 2012 | 06:46 PM
dykaar's Avatar
Default Update:
I pried out the pieces of the impeller. Now I see that the nut is spinning on the shaft, and the washer (92022-1393, 6X14X2) is missing. Even if the thread was correct, it may be beyond the threads now. At least I'm not looking at splitting the cases.
Old Jun 20, 2012 | 07:31 PM
dykaar's Avatar
Default Another update
I got the nut off by crushing it with a nut cracker. That squeezed it enough to get it started on the threads. It bunged the threads on the rod a bit, but its usable. By not using the washer on the rod, the cast impeller was broken when forced over the larger diameter portion of the rod.
Now I need a new impeller...
Old Jun 20, 2012 | 08:21 PM
MaverickAus's Avatar
Good luck with it
Old Jun 22, 2012 | 10:11 PM
dykaar's Avatar
Thanks. She'll be right, mate. Bought two impellers off ebay. Cheap enough to have a spare.
JohnnyT83
Aug 21, 2013 11:14 AM
jry48152
Jul 6, 2010 03:24 AM
mgmshar
Jul 23, 2007 01:30 PM
ekoster
Sep 22, 2006 06:25 PM
oneeye212000
Aug 4, 2006 03:02 AM
