92 kx250 and 91 kx 250 parts interchangeable?
Old Jul 6, 2007 | 12:50 AM
tramatbay's Avatar
Default 92 kx250 and 91 kx 250 parts interchangeable?
I have a 92 kx 250 and replaced the front forks with ones from a 91 kx 250. The front brake mount on the fork is 2 1/2inches center to center on the 91 forks. The mount on a 92 is larger, about 4 inches. The front brake caliperassembly numbers match for a 91 and 92. The only difference from the parts finder listis the front disc and front caliper holder assembly (figures). Does anyone know if the 91 front caliper holder assemblywill match the 92 front caliper to mount to the fork? I thinkwill but could not confirm from local kaw dealer.
Any help will be greatly appreciated,
keith
Old Aug 26, 2007 | 06:43 PM
kx slaughter king's Avatar
Default RE: 92 kx250 and 91 kx 250 parts interchangeable?
88-92, 93-00, 00-04. theyre all the same bikes and most of the parts should be interchangealbe no problem.
Old Oct 25, 2007 | 01:57 PM
KickassKX's Avatar
The reason the brake mounting is bigger on the '92 is beacase 92 onwards have dual piston calipers
Old Jan 2, 2019 | 06:07 AM
bt1985250's Avatar
Default Help
Ok,I am in need of all the wiring, CDI, coil zetc for my 91, can't find ****, will 88,89,and 92 work? Thanks
Old May 14, 2020 | 02:42 AM
Chase Anderson's Avatar
Default 91 Kx 250
Will a crank from a different year work in a 91 kx250
bennythejet33
Oct 2, 2015 04:18 PM
pontakoj
KX250 & KX250F
Oct 23, 2013 07:57 PM
Kx250 92
KX250 & KX250F
Dec 19, 2012 04:25 PM
dirtridr
KX250 & KX250F
Feb 20, 2008 01:13 AM
bansheedave
Sep 24, 2006 04:55 AM
