1994 KX 250 Rear Caliper Fitment
Old Sep 7, 2017 | 12:05 AM
midwestkx's Avatar
Default 1994 KX 250 Rear Caliper Fitment
I'm looking to purchase a rear caliper for my 1994 KX 250 as it's currently non existent. The closest I can find is coming off of a 1994 KX 125. Are these the same caliper? If not, what are my other options in regards to finding a caliper? Thanks in advance for any input!
Old Sep 7, 2017 | 02:16 PM
The assembly is the same as the KLX650 from 93-96 in the U.S. Maybe more years in other countries. But you likely can find a used KLX650 unit. You could go to the ADVrider forum, in Thumpers in the KLX650 riders UNITE thread and ask for one.
That is the problem - they list the caliper AND carrier. The caliper may have been used on dozens of bikes, but the carrier maybe on one or two.
The brake pads are shown being used by numerous older model Kaws, so those calipers may work. Check here at Partzilla It shows that KX125 caliper using the same brake pads, so it's worth a try. I doubt you should spend over $20 on a used caliper.
Old Sep 8, 2017 | 08:58 AM
MaverickAus's Avatar
Kawasaki 01 CALIPER-ASSY,RR Details of 430411532
Year Model Fiche Section
1992 KX500 Rear Brake(kx500-e4/e5/e6/e7)
1993 KX500 Rear Brake(kx500-e4/e5/e6/e7)
1994 KX125 Rear Brake
1994 KX250 Rear Brake
1994 KX500 Rear Brake(kx500-e4/e5/e6/e7)
1995 KX500 Rear Brake(kx500-e4/e5/e6/e7
roccitman
Jan 11, 2016 10:30 PM
thekeeper199
Sep 27, 2014 09:22 PM
Ralphh85
KX250 & KX250F
Jun 17, 2014 09:28 AM
tycar86
Ninja 500R
Oct 17, 2006 03:13 PM
May 31, 2006 12:27 AM
