2004 KX 125 Rebuild
Old Jan 13, 2016 | 02:30 PM
DP8201's Avatar
Default 2004 KX 125 Rebuild
I recently took on the project of rebuilding a 2004 KX 125. I have completed everything except the motor. I am in need of some help or suggestions as to a problem and advice on another:
It runs great at low to mid rpm's. When you really get the rpm's up in the higher range there is what feels like a serious vibration coming from the motor. First thought was loose motor mounts. But nothing was loose. Any ideas what this might be?
I also pulled the cylinder and head to look at the crank. The crank looks brand new with no signs of getting to hot. It does how ever have quite a bit of side to side movement where the rod connects to the crank. I know there should be a little but this seems like a lot.
Any help would be appreciated.
Old School
KX125
Jun 8, 2013 11:47 PM
cmagrey12788
Oct 29, 2010 02:17 AM
1991ZX600R
Nov 23, 2006 08:40 PM
indix1
Nov 6, 2006 05:59 AM
walight01
Aug 16, 2006 06:27 AM
