03 Kx 125 clutch problem Need help
Old Feb 24, 2008 | 08:42 PM
atrimbleracer's Avatar
Default 03 Kx 125 clutch problem Need help
I just bought a 03 kx 125 for cheap and it has a bit of a clutch problem. on the left side of the engine where the clutch is, the guy wrecked and broke a little piece off, directly behind the flywheel cover. it is right where the little clutch lever and the clutch pushrod meets. the push rod and the ball that goes inside are missing. I think the ball goes in first, then the pushrod, then the lever goes at a right angle the the pushrod. if there is anyone who knows the size of the pushrod, or the ball, knows the order it goes in, or a diagram of how it all goes in. Please help me so i can ride with a clutch again.
Old Feb 26, 2008 | 05:43 PM
Bobba Ganoosh's Avatar
Default RE: 03 Kx 125 clutch problem Need help
I also have an 03 KX125 and when i have problems like that i go to www.bikebandit.com. If you go in the OEM section then find the clutch section it will show you a diagram of how it goes and a part list of every little part that goes there. Hope this helps.
Dscott
Jun 11, 2013 11:13 AM
disasterouskid14
KX125
Jul 20, 2009 03:02 AM
Spohnmeister
Jun 22, 2009 04:20 PM
ollisdadda
KX125
Mar 15, 2008 02:30 AM
atrimbleracer
Feb 25, 2008 04:32 PM
