2023 Klx 300ds
Old Dec 28, 2022 | 07:30 PM
Kris250's Avatar
Default 2023 Klx 300ds
I’ve been off here for years cuz I sold my 250s but now I miss it and bought 2023 300ds. I just purchased the barker exhaust and dyno jet fuel controller for the lid less set up from barker it has there tune. I was wondering if I should delete the o2? They said no but when I bought the same set up for my 2018 250s it came with o2 delete.
Old Jan 11, 2023 | 09:37 PM
Discoveror's Avatar
The computer fuel injection depends upon various sensors to map the correct fuel sent to the combustion chamber to obtain the stoichiometric air:fuel ratio (~14.7:1) in the combustion chamber; one of those crucial sensors is the O2 sensor, which detects exhaust oxygen content ... and sends that reading to the computer ... which uses the exhaust oxygen content to adjust fuel going to the combustion chamber. Remove the O2 sensor and the computer has no way to adjust the fuel correctly.
Old Jan 12, 2023 | 12:54 PM
Dig around here a bit, there has been some discussion. It might be in the KLX250 forum, but does have some new 300 riders too.
Old Jan 12, 2023 | 03:37 PM
tooter's Avatar
I believe the O2 sensor will try to compensate for the manual settings on the dynojet.
I run a custom exhaust with the stock 02 sensor and no controller because I ride for transportation, so the engine is always operating in closed loop mode where the sensor controls the a/f mixture. I get excellent gas mileage with 75mpg average in Winter and 85mpg in Summer.
Old Jan 13, 2023 | 03:09 AM
Olderider's Avatar
I installed the dyno jet fuel controller and removed the O2 sensor. Had it dyno tuned and the fuel controller takes care of all the fuel needs. So O2 sensor isn’t needed.
Also did the same on my R3
Old Jan 7, 2024 | 02:15 AM
Olderider's Avatar
I sold my 22 but now have a 23. I did the barker full exhaust with the EHS tuner , removed the secondary throttle plates, took off all emissions and air injection. With this set up they said to leave the O2 sensor in. I do have a delete plug but I just left it in.
Old Jan 7, 2024 | 07:38 AM
tooter's Avatar
I also installed a tuner but no dyno. It positively slaughtered my gas mileage. I was getting 80 mpg, and now am barely getting 60. So I'm going to lean it out a little and see if it improves.
Old Jan 7, 2024 | 09:30 PM
Olderider's Avatar
That’s a huge hit on MPGs wow
Austin97
Jul 27, 2022 01:35 AM
bweekley
Jun 9, 2010 04:59 PM
niven
Apr 28, 2009 02:46 PM
JonnyD
Jun 5, 2008 02:45 AM
deej
Jun 14, 2006 06:41 AM
