Wiring help! Aftermarket fender eliminator with turn signals.
Old Jan 7, 2020 | 11:41 PM
fitpays's Avatar
Default Wiring help! Aftermarket fender eliminator with turn signals.
*** SOLVED***. 10amp fuse under seat. Hey guys. I bought a cheap eBay rear fender for 2009 KLX250s. Well, you definitely get what you pay for. No wiring instructions, and it required all sorts of modifications to fit. I finally have it figured out (I think) but not before I think I blew the fuse for the rear running light. I think I blew the fuse or otherwise screwed something up. If I put a rubber band around front brake lever, brake light is working. If I touch the running light wire to it, it lights as well. But the red wire from the bike that should be the rear running light is not working. I’m not getting any juice from it. About to test the ground individually so I know it’s definitely not that. Do you guys know if there is a fuse SOLELY for the running light, and if so, where it’s at?! I hope I didn’t blow a relay or something in the bike.
Old Jan 8, 2020 | 04:31 PM
Are you going to post any pics after the full install? Here are a couple of mine from back in 2006.
Old Jan 9, 2020 | 03:36 AM
fitpays's Avatar
I will try to post some pics for you guys soon!
93Octane
Jun 19, 2015 11:39 AM
alexfj
Nov 9, 2012 09:16 AM
WindyCityKawi
Sep 17, 2010 06:53 PM
gpyo05
Sep 17, 2008 03:39 AM
uponone
Aug 31, 2007 01:32 AM
