Widest rear tire for an SF
Old Jun 15, 2011 | 03:48 PM
cegusman's Avatar
Default Widest rear tire for an SF
What is the widest tire I can put on my SF before getting into the swing arm? Stock is 130/70x17. Will a 140/70x17 or 150/70/17 fit?
Old Jun 15, 2011 | 03:55 PM
Matasickle's Avatar
140 should fit.. 150 would be pushing it..
Old Jun 15, 2011 | 04:02 PM
cegusman's Avatar
Yeah thats what I have just found doing some Google searching. Looks like a wider rim is needed for the 150
Old Jun 15, 2011 | 04:09 PM
Matasickle's Avatar
I don't see a need for anything bigger than a 140 anyways..
Old Jun 15, 2011 | 05:41 PM
cegusman's Avatar
Thats also what I was thinking
Old Jun 15, 2011 | 07:28 PM
go cytocis's Avatar
My research concluded 140 metric, or 5.10 imperial.
Your question begs another however: are you looking for handling or aesthetics? If it's the former, wider isn't always better. If it's aesthetics, do as you please.
Old Jun 15, 2011 | 08:22 PM
cegusman's Avatar
Looking for handling. Playing around corner's working on dragging knees and the stock tire seems to want to break free a little to easy.
Old Jun 15, 2011 | 08:42 PM
akarob's Avatar
The stock tire size is more than enough for that bike. It you experience traction issues, perhaps your air pressure is a bit too high (or low).
You could certainly also get a softer tire.
Old Jun 15, 2011 | 08:46 PM
go cytocis's Avatar
I have no experience specifically running a 130 back-to-back with a 140, but I do have experience with a 180 & 190 on the same bike & same track. My observations may translate (or, not?):
-I noticed that the narrower tire turned-in to corners easier & more neutrally
-I noticed that the narrower tire tracked better through corners
-I noticed no difference in traction under acceleration
-I noticed no difference in traction under braking
Additionally, I’d suggest that there are other factors such as compound & profile, which vary by manufacturer, that have a greater impact on handling/traction, than the width. Pressure & temperature also play important roles.
All this is to say that in my experience, a wider tire may not be the solution to your problem, particularly if you haven't exhausted less costly options first...
Old Jun 15, 2011 | 09:30 PM
cegusman's Avatar
Guess i will stick with the stock size for now.
