Who carries a hand pump??
I got a CO2 unit and also carry three cartridges. The one I got will use the bb gun size too. One of those will get a flat rear tire to 10 psi. Never needed it, but now I'm gonna carry a few extra just in case.
I would just be soooo mad if i didnt get it on right and hit it and all the CO2 just went everywhere except into the tube. With a pump it may take a little longer but i know it will work in the end.
Shadetree, do you have the cane jack style of portable jack for the bike? If so, I mount mine like a crossbar with zip ties. My Renthal bar doesn't have a crossbar, but if it did, I could mount it the same. Look in the one pic of my bike, and you can see where I zip tie it. I put rubber bumpers over the ends of the cane jack to cushion it against the bar. I've been thousands of miles with this setup, and the cane jack has never moved or come loose. I put the fork end in that tail bag on the bike. I carry the Mountain Morph mini pump in my hydration pack, but there are many creative places to put the pump, similar to what I did with the cane jack.
The one I have gets threaded on to the valve stem. It also has a trigger to control the flow. My only real concern is not getting the bead set or messing up the patch job and not having enough CO2 for a second try.
I use a cheapie bicycle hand pump, I think it's a Bell brand pump. It was only eight bucks or so. It appears to be all plastic, and not what I would call particularly burly looking, so i won't use it as a pry bar or hammer. However it is quite compact (less than 10-1/2" long), very light, and fits nicely in my compact tool kit. i currently keep my entire tool kit in a Pelican 1170 box mounted directly to the fender in place of the OEM tool bag. I've used this pump to do a tire change in the garage and it does the job just fine; not as good as a full size manual pump or ideally an air compressor, but more than sufficient for the trail.
I don't like CO2 cartridges as a sole source of inflation gas, as I've seen folks run out of them before a tire is seated on the bead, and i've seen duds straight from the package...you'll never know that they're not charged until you need them. I actually don't use them at all, but if I did, I'd still have a manual pump. Plus, they're damn expensive.
I'm a cheap skate, but $16 bucks ain't expensive.
Genuine Innovations Ultraflate Plus Tire Inflator - Chaparral Motorsports
15 CO2 cartridges at wallyworld is only $8 bucks. I haven't found a dud yet.
JT 12 Gram Co2 Cartridges - Walmart.com
I have had my share of broken hand pumps and 12V compressors. If I come across a quality manual pump I'd probably buy it as a backup. I've been pretty happy with my current 12V compressor. Going on 4 years old. The 12V plug broke shortly after I got it, but it's been great since I replaced the plug. The little guy will even fill 80 psi RV tires. I use it all the time when I need to air up my baja and Jeep. It's a MasterFlow MF-1040 I picked up onsale for $25 at Pepboys. Tough little unit... other than the plug.
I bought a lezyne hand pump from REI. This thing is super compact and light weight. I also bought a small slime compressor that is super compact but weighs a lot more than the hand pump. I can power it from the bike battery.
High roller!
Did I also mention that all the extra cartridges you need to bring along are super bulky?
