wHERE IS EVERYBODY FINDING FRONT SPROKETS?!?!
Old Feb 4, 2013 | 04:36 PM
Sam Trimble's Avatar
Default PBI Sprockets
466-13 KLX-250S for under $20. Made in the USA Good luck
Old Feb 4, 2013 | 05:52 PM
Lawnica1's Avatar
Thanks for all the links guys! Just one more question before I order one.
I already have grooves in my plastic swingarm protector from the chain rubbing on it. When I drop a tooth will it completely eat up the protector? Should I get a rear sprocket instead so I can get the chain up off the swingarm? I checked my chain slack and I'm pretty sure it's within spec.
Old Feb 4, 2013 | 09:15 PM
ol'klx-er's Avatar
A couple of grooves from the chain side plates? That is normal. Once the rollers contact the swingarm protector as well the wear slows down.
Old Feb 4, 2013 | 09:38 PM
As ol'klx-er said, that's normal. Keep an eye on the swingarm slider. Don't let it wear through. But you should get plenty of miles out of it, even with the 13. When you need a replacement, keep these guys in mind:
Hot Foot Moto LLC
Old Feb 5, 2013 | 12:38 AM
Lawnica1's Avatar
Yup that's it from the side plates of the chain. Thanks a lot guys! glad I don't have to get a rear sprocket because those are expensive
Old Feb 5, 2013 | 12:39 AM
Lawnica1's Avatar
Also those guys look good thanks for the link IDRIDR
Old Feb 5, 2013 | 02:41 PM
Amazon is great, I've spent nearly $5000 in the last few months, and everything has been as expected. I challenge myself sometimes to try and see if something I need for work is not on that site, and every time I still find it. Simply amazing!
Old Feb 7, 2013 | 07:36 PM
Lawnica1's Avatar
Welp I took a leap of faith and tried amazon they had a sunstar 13 tooth for $20 and the part number was the same as sunstar's website 3B113. Thanks for the advice fellas!
alexgg
Mar 22, 2011 01:14 PM
Dezrider
Nov 9, 2010 09:37 PM
punkenduro09
Sep 24, 2009 11:47 PM
p2thec
KX250 & KX250F
Dec 12, 2007 01:39 PM
Evergreene529
Ninja 250R
May 9, 2007 10:09 PM
