Where to buy the HMF slip on?
Old Nov 14, 2006 | 06:06 PM
Marty's Avatar
Default RE: Where to buy the HMF slip on?
Actually, the Quiet Core is free - if you join their website!
Here's how it works, join the HMF Engineering website - have a screenname and ask for a discount.
They give you $20 off on the order of the slip on.
The Quiet Core costs $20. So, in essence, it's free to members of the HMF Engineering forums.
It's a piece of cake to put the quiet core in. Took me all of 3 minutes to figure it out, without reading the directions. Probably would have taken longer if I took the time to read the directions.
You can installed the quiet core with a spark arrestor, or a spark arrestor or leave both out.
Quite flexible.
Perhaps this weekend it's time to do the "Flange Mod" and then "Bolt-R-On!"
Old Nov 18, 2006 | 02:54 AM
Marty's Avatar
I know which of these exhaust cannisters looks better. I also know which one weighs less.
Now I need your help, which one do you think flows more air?
Old Nov 18, 2006 | 04:25 AM
onestarr99's Avatar
Marty, it looks great!!![sm=smiley20.gif] I'm very interested in the HMF and I would love to hear how it sounds.. .Is their any way you could post a small video?..... Thanks
Old Nov 18, 2006 | 04:59 AM
Marty's Avatar
I will see what I can do.
However, with the quiet core in, it's just right!
Does get just a bit noisy - deep throaty sound - without it. Of course, I'm not into loud exhaust!
Old Nov 18, 2006 | 05:12 AM
Thunderchild's Avatar
Looks nice Marty. I'm following your progress on this project. I'm thinking of going the same route you did. Post some pics when you get that bad boy on the bike.
Willum
TC
Old Nov 18, 2006 | 05:15 AM
IchWarriorMkII's Avatar
Im getting used to the growl, definatly a change from all the other choked down dual sports I've ridden!
The funny thing is to cover the exhaust while the bike is idling to warm up... I had to cover the entire opening up to make it 'sound' like the stock exhaust! It was definatly NOT flowing...
Old Nov 18, 2006 | 07:20 AM
tremor38's Avatar
Go back, look at the opening of the stock muffler, compared it with the diameter of the stock headpipe then try to tell us all again where the bike is being "choked."
ORIGINAL: Iowaguy
looks nearly as well built as my BigGun although I don't care for the end tip- it looks too much like the Muzzy which I think is too sportbike exhaust looking. are you going to change out the header pipe? I assume you know that the headpipe is what chokes the 250 and doesn't let it breathe. congrats on the pipe.
Old Nov 19, 2006 | 01:25 PM
tremor38's Avatar
ORIGINAL: Iowaguy
ORIGINAL: tremor38
ORIGINAL: Iowaguy
tremor- OK, you don't believe me about the header pipe choking the KLX 250/300. That's okay it's your bike. That's the reason why people who own the KLX 300R replace the header pipe and keep the stock muffler (removing the buttplug albeit) because it has been proven to make as much or more power than some slip-ons. Sure the KLX 250S' muffler chokes it also, I never said it didn't. It has a catalytic converter inside for petesake. Sure you need to rip it off your bike asap, but you also need to pitch the header pipe.
By now if you have one (one of the FMF or HMF, whatever the brand slip-ons) and got it installed on your bike you're probably feeling all warm and tingly inside about your bike, maybe you've rejetted. But guess what, it still isn't breathing like it should. The oem header pipe isn't a machinists' best work. Take it off, look inside. And as Forrest Gump would say, "That's all I got to say about that".
I never said that a gain couldn't be made by going to a larger diameter headpipe. What I'm trying to say is that the MAJOR obstruction on OUR machines is in the muffler. The wording in your original post was that the restriction is in the heapipe with no mention of the muffler at all.
What I'm saying is backed-up by numbers as well. An independent testing firm in Japan ran before/after tests on a wide variety of slip-ons and full exhaust systems. The average gain from any slip-on was about 2HP. The gains from a wide variety full exhaust sytems were between 2.5 and 3HP. As an example, your BG EvoX yielded just over a 3HP gain...not bad. We're talking rear wheel HP as measured on a dyno. So, I think it's safe to say that, with a decent aftermarket full exhaust, 2/3 of your gain is from the muffler while the remaining 1/3 comes from the headpipe. I think changing the headpipe on the 300R might have a bit more effect because the larger displacement moves more air.
Old Nov 19, 2006 | 08:21 PM
onestarr99's Avatar
ORIGINAL: Marty
Thanks Marty, I am not into a loud exhaust either. Just looking for a better sounding exhaust note (not too loud) and a little proformance..[sm=smiley20.gif]
