Whats the best spark plug for my bike!!!!!
Old Aug 14, 2008 | 01:28 PM
Default Whats the best spark plug for my bike!!!!!
Lookin to find a hotter plug,, opinions plz
Old Aug 14, 2008 | 02:40 PM
WestOzKLX's Avatar
5. Heat Range Selection
Let's make this really simple: when you need your engine to run a little cooler, run a colder plug. When you need your engine to run a little hotter, run a hotter spark plug. However, NGK strongly cautions people that going
to a hotter spark plug can sometimes mask a serious symptom of another problem that can lead to engine damage. Be very careful with heat ranges. Seek professional guidance if you are unsure.
With modified engines (those engines that have increased their compression) more heat is a by-product of the added power that normally comes with increased compression. In short, select one heat range colder for every 75-100 hp you add, or when you significantly raise compression. Also remember to retard the timing a little and to increase fuel enrichment and octane. These tips are critical when adding forced induction (turbos, superchargers or nitrous kits), and failure to address ALL of these areas
will virtually guarantee engine damage.
An engine that has poor oil control can sometimes mask the symptom temporarily by running a slightly hotter spark plug. While this is a "Band-Aid" approach, it is one of the only examples of when and why one would select
Old Aug 14, 2008 | 02:48 PM
thanks Oz great help
Old Aug 14, 2008 | 02:49 PM
Old Aug 20, 2008 | 12:46 AM
wynn711's Avatar
Default NGK Iridium
NGK Iridium with all the mods my bike is running perfect and the plug shows the fuel/air mixture is perfect as well. Cannot tell you how all the mods worked so easily if you follow them and the NGK Iridium Plug is a perfect match for all the 07 KLX Mods.
Old Aug 20, 2008 | 03:17 PM
ZX1100F1's Avatar
+1 on the NGK Iridium Spark Plug.
Old Aug 20, 2008 | 03:31 PM
kgwld1's Avatar
I put the ngk iridium plug in and it really did clean up my choppy idle, and before sometimes I needed to choke it slightly when cold not anymore. Does it work seems to, buy one for yourself and you be the judge. Whats $9 bucks.
Old Aug 20, 2008 | 03:35 PM
almost 2 gallons of gas lmao but serisouly ill go try one out
Old Aug 20, 2008 | 03:42 PM
chris72a's Avatar
Been thinkin' of trying one of these iridium plugs, but truth be told I couldn't be bothered pulling the plug to get the part # to match it, anyone got this handy..
Cheers
Chris.
Old Aug 20, 2008 | 07:24 PM
KLXtrailrider's Avatar
CR8EIX I think
