What is wrong with my kickstand
Old Apr 7, 2020 | 04:17 PM
Nietzsche's Avatar
Default What is wrong with my kickstand?
Just bought this bike used. The angle that it sits at is crazy. Could the kickstand tab be bent? Should I just weld some sheet metal to the bottom in order to make it longer?
Old Apr 7, 2020 | 06:16 PM
durielk's Avatar
Glue a block of wood to the bottom of the stand to lenghten it until your happy, it does look a little more sideways than most.
Old Apr 7, 2020 | 06:19 PM
Nietzsche's Avatar
lol good idea
Old Apr 10, 2020 | 07:15 AM
snappster's Avatar
Might be a SF kickstand on the bike. It is a bit shorter than the S kickstand. Post up a photo with a tape measure on it. I have both and when I switch between my 17" and 18/21" wheels I change out the kickstands too else the bike leans too much or is too vertical depending on which stand and wheels are on the bike. Edit: I just took a rough measurement of my two kick stands and found the SF stand to be 2.5-3 inches shorter than my S stand. Definitely more than 2.5" difference. That's more than the thickness of a 2x4 under the stand.
Old Apr 11, 2020 | 12:02 AM
BCLS482's Avatar
My bike is the same. I think it's because I stand on the left side footpeg to climb on. Please post your solution.
Old Apr 11, 2020 | 02:18 AM
Nietzsche's Avatar
i just measured my kickstand it is 11.5”
Old Apr 11, 2020 | 02:21 AM
Nietzsche's Avatar
yea I was thinking that the PO may have bent the tab. He bent the Right side foot peg mount. I was able to beat it level with a 3lb sledgehammer. I have a new pair of DRC pegs in the mail. If my kickstand is the right one for my bike I will bend the tab back with the sledgehammer.
Old Apr 11, 2020 | 02:37 AM
durielk's Avatar
My 07 is a little over 13" from CL of bolt to end of flat part. ... and wash that thing before you start working on it!
I don't think bending the tab is going to be much help if your that far off. I still think a 2x4 could be made just right. And you will not break anything ... else.
Old Apr 11, 2020 | 04:07 AM
snappster's Avatar
My SF kickstand measures 11" from the bolt hole center to the pad, so it looks like you have the short stand. I would just find the correct kickstand instead of jury rigging something. Edit: I also measured my S stand at around 13.5" from bolt to pad.
Old Apr 11, 2020 | 02:21 PM
Nietzsche's Avatar
great info thanks. I will look for one on fleabay. Unless anyone here wants to trade?
