What wheels are compatible with a 2022 KLX300SM?
Old Jun 27, 2022 | 12:30 AM
KLXenjoyer's Avatar
Default What wheels are compatible with a 2022 KLX300SM?
I'm trying to get a set of 18"/21" wheels for my KLX300SM. Can anyone help me out with what is compatible? Will any KLX250 dual sport wheel from 2009+ be a direct fit with the same spacers and everything? I know the front rotor is different so I was already expecting to swap that over.
I assume the speedo will be incorrect unless they have different gears in the pickup like what I saw between the dual sport and sumo DRZ. Is there any way to recalibrate them or will I just have to deal with it?
Old Jun 27, 2022 | 11:05 AM
From what research I've done, they should all work. Rear wheels actually have a wider variety beyond the 2009 model. The front needs that electronic drive setup.
Old Jun 27, 2022 | 04:47 PM
Tacoma660's Avatar
Random thought, how would the bike handle on 18s front and back? 4.10 on the front and 120 or 130 in the rear?
Old Jun 27, 2022 | 04:58 PM
greychinos's Avatar
Seems like you'd be limiting your tire choices, no? Would the idea be to run a scrambler style tire that might handle better on-road than 21/18 but still give you some dirt traction?
Old Jun 27, 2022 | 05:11 PM
Tacoma660's Avatar
I’m pretty set on the Shinzo 705s as I have yet to find something they aren’t good in besides mud
Old Jun 27, 2022 | 05:31 PM
Tacoma660's Avatar
I’m just curious how the handling would be compared to the 21/18, as I do way more road riding then ever but don’t really want to do 17s
Old Jun 28, 2022 | 12:23 AM
If I did an 18 on the front I'd run a 100/90-18 front and a 110/90-18 rear The narrower tires would draw less power and work well on the road.
I have run a 21/17 set up on my KLX650 for about 50,000 miles riding a lot of pavement play chasing friends on supermotos. I ran Duro Median dual sport tires and could hang with them in the turns, they got me with more horsepower on the straights. On my 250 I am running the 21/18 running the Duro Medians as well, but using a 4.10-18 rear instead of the 120/80-18. Uses less horsepower and works better in sand and mud The narrower tire doesn't bog down as easily.
Tire choice is the player in what should be done. I saw a rider at a NASMoto supermoto race around 2004, running a clapped out Honda XR600R with a rough Dunlop Sport Elite on the back and a 3.00-21 Metzler ME-33 Laser street tire on the front. He was beating new 450 KTMs with that set up. Of course it was a lot of his ability to ride, but the tires were far from cutting edge.
Old Jun 28, 2022 | 12:19 PM
Tacoma660's Avatar
That’s good to hear, I’m not the best rider in the corners but was curious if an 18 front would make that much of a difference for the cost of a conversion. The 120 in the back with the 351 kit feels awesome to me. I’ll probably keep the 21/18 setup, just a slow time that gets the brain thinking.
Old Jun 28, 2022 | 01:57 PM
I'm still no where near as comfortable with my 250 as I was with the 650, it takes time.
Old Jul 2, 2022 | 03:30 AM
bryantjt's Avatar
I ordered the oem 18/21 wheels from the 2022 klx300 for my 300sm from rockymountainatv.com. It took almost 3 months to get them but I couldn't find any used wheels of the correct year for the front and I needed the correct rotors as well since there's no aftermarket ones.
If you go that route, the wheels come with the bearings and spacer tube installed. I wasn't sure so I ordered everything and now have spare parts.
