What to do after bike takes a nap?
Old 02-21-2014, 01:56 AM
Wsc7050's Avatar
Default What to do after bike takes a nap?
So today I didn't make it all the way up a long steep climb. I ended up most of the way down the climb so the bike was on its side for a couple minutes before I got back to it. It didn't want to start right away so I had to crank it a bit and then open the throttle and crank. It fired and all was fine. I know that it flooded, but why? And then what is the best way to deal with it? Just interested. I have the pumper carb. Thanks!
Old 02-21-2014, 02:09 AM
TNC is offline
You generally can start a flooded engine by opening the throttle fully open while cranking...or kicking. More air to mix with the already fuel rich condition. The engine floods because the fuel in the float bowl is now trying to flow up the needle jet while the bike is/was on its side...or upside down. The usually added temperature at the time of a crash only aggravates the issue caused by flooding. Even with a CV carb, a flooded engine benefits from opening the throttle plate as the cranking engine will still lift the vacuum operated slide, allowing more air.
Old 02-23-2014, 02:26 AM
linkin5's Avatar
1+ on what TNC says, I've started more flooded bikes and 4 wheelers (usually other peoples) by simply holding the throttle open for a few cranks. If you have a pumper carb don't flog just hold it open.
GS247
05-07-2007 07:10 PM
markmeinteil
12-15-2006 06:23 AM
BleedGreen
10-31-2006 07:31 AM
ryninger
09-21-2005 05:15 AM
Violet_Vixen
07-11-2005 01:49 AM
Quick Reply: What to do after bike takes a nap?
