What a difference...
Old Sep 15, 2010 | 03:46 AM
Originally Posted by Blackheart58
Thanks. Certainly know the if's and's and but's have been figured out...even if it was by trial and error. Just have a curiosity about the physics. Interesting you should mention postive pressure intake systems...most are in Fuel injection systems, I'd think. With venturi setups, it seems it could screw with the flow (and therefore, pressure gradients) across the jet, leading to a whole 'nother set of complications. Obviously...I just don't know very much about it. Thanks again!
Actually if I recall, some of the first Ninja's with ram-air were carbed. And there have been some muscle cars with a functional ram-air that dyno'd an actual power increase...one of the Olds 441's and/or W31 seemed to have the best system...and apparently it wasn't just a cold air benefit because they tested with and without an introduced air flow to mimic a moving vehicle. But you're right...some carb/air intake setups can cause intake havoc. When the K&N individual air filters were popular for mulitcylinder bikes, some worked extremely well under most any conditions and some would get weird fuel/air delivery issues at speed or other situtions. I'm pretty sure our CV carbs are not good candidates for this type of filter or running open to the atmosphere. They seem to perform better with some modicum of dead air space prior to the carb inlet because of the more sensitive vacuum slide.
Carbs are at one moment quite simple while at the same time often confounding the best tuners with a funky problem. This is where many would claim the FI system to be the cure for everything, but just wait until a throttle position sensor or one of the myriad other sensors throws you a curve...or the fuel pump in the tank goes out...or the computer signs off. Nothing's perfect.
Old Sep 15, 2010 | 09:13 PM
Blackheart58's Avatar
I guess if the Venturi were far enough downstream, it's the flow of air across the opening, and not so much the actual pressure in the column of air that matters the most. Then again, to get the MOST fuel when relying upon the Venturi effect, I would think the actual location of that opening in relation to the smallest airway opening would depend partly upon whether we had boosted intake pressures or, conversely, more negative intake pressures. Seems like Fuel Injection would yield much more precise titration. As you mentioned: with precision comes the "other" reliability issues...TPS's being a common one, as well as fuel pressure regulator sensors, etc.
Anyway, thanks for helping with my curiosity on the subject!
Old Sep 18, 2010 | 05:01 AM
T_i_G_e_R's Avatar
put a kdx snorkel on, it supplies enough air, and keeps it QUIET.. I think the air limiting step on the stock klx was the snorkel.. try running with the lid off and compare to snorkel removed.. no difference in performance i bet.. just mt 02
ZX_9r
Ninja ZX-9R
Jun 25, 2006 01:57 AM
jared
Ninja 250R
Apr 28, 2006 11:48 PM
Fremont250
Apr 18, 2006 04:58 PM
pimpswithmints
Joke section!
22
Mar 20, 2006 07:11 AM
wanna6r
Feb 26, 2006 09:57 PM
