Web Cams 101 instalation
I have just received a set of WebCams, 101 grind. I plan to drop them in this weekend, along with a KK 331.
Questions. Is this a straight forward cam instalation. Am I going to need a degree wheel? I have a shim set from HotCams so will check and adjust clearances if needed. Any advise or pointers from forum members that have installed Webcams will be greatly appreciated. |
Degreeing cams is usually beneficial under most any circumstances, but it's especially worth it if you've spent money on aftermarket cams. Still, I bet you'll get a bump in performance even if you don't.
I think the webcams, at least the 101, are supposed to be drop ins (shimming may be required on the valves however). as tnc said degreeing might help but I doubt you would see much gain outside of back to back dyno pulls at least on the klx.
My Web 101 cams were drop in. Nothing needed special just adjust your valves to spec.
How would you degree these cams anyway in this motor? I think you would have to slot the cam chain gears on the end of the cams to get any adjustment? I could be wrong? This seems too much work for little improvement if any? But I follow the rule every little bit adds up, so it may help some? |
Originally Posted by wild will
(Post 498453)
Originally Posted by TNC
(Post 498455)
Yes, that's the general method on a bike like the KLX...slot the cam gears.
Thanks for the answers guys. Drop in and adjust clearances seems the way forward. No way that I am about to start slotting cam sprockets.
I will report back on the Bump from 300 to 331 with Cams. Just hope it was worth the cash. |
Originally Posted by grahamgower
(Post 498484)
I will report back on the Bump from 300 to 331 with Cams. Just hope it was worth the cash. My mechanic dropped the 101's straight in with no problems. Make sure the shims are at the loose end of the tolerance scale. There was a little more noise from the topend after fitting the lumpier cams but my mechanic said it was to be expected from an already not so quiet thumper engine! And that was many thousands of miles ago & still sounds the same. Enjoy some more torque in the low/mid rpm range & that extra 1000rpm of topend power before the power curve starts to drop off. Every little extra HP counts on these light weight SuMo's. |
Following this with much interest.
Im trying to decide just what to go for on my new KLX250 EFI. Already messaged some of you, asking for advice. This is a very good chance to get to know the difference between the 300cc and 331cc kit and also the cams ofcourse. Once you have rolled a few tankfuls, I am very interested in hearing what it has meant for your fuel range and such things. I want to thank everyone for sharing all this good information! |
Originally Posted by Nikolaj Lykke
(Post 498493)
