Vapor mounted
Old Nov 12, 2007 | 01:12 AM
redbrd's Avatar
Default Vapor mounted
I mounted my Trail Tech Vapor this week,very impressed with this little unit,
everything seems well thought out,but i was not sure the handlebar mount was sturdy enough for off road use
so i made my own, and tested it today everything worked great.
Old Nov 12, 2007 | 01:28 AM
Shadetree's Avatar
Default RE: Vapor mounted
Dean,
Nice work on the plate. How'd youget the engine turned look on the aluminum? That's a clean setup. The wiring looks first rate as well. Clearly, you've been there before. How do you like the Vapor now that it's installed?
Bill Dragoo
Norman, Oklahoma
Old Nov 12, 2007 | 01:33 AM
green242's Avatar
What did you do about the original bracket? And the headlight? I want one of these as well! Can you make mee one of those mounts
Old Nov 12, 2007 | 01:34 AM
bryantjt's Avatar
The sidepods with lights appear to be a new addition as well. If I remember right Brian had to fab his own for indicator lights.
Old Nov 12, 2007 | 01:43 AM
redbrd's Avatar
ORIGINAL: Shade tree
Dean,
Nice work on the plate. Hold youget the engine turned look on the aluminum? That's a clean setup. The wiring looks first rate as well. Clearly, you've been there before. How do you like the Vapor now that it's installed?
Bill Dragoo
Norman, Oklahoma
Thanks the engine turned look is easy, roll up sand paper or emery cloth real tight and put it in a drill, and push lightly.
on the surface,
the Vapor worked great, nice and bright easy to see.
Old Nov 12, 2007 | 01:50 AM
Shadetree's Avatar
I thought that might have been how you did it. That, or by using a small diameter Scotchbrite disc on a die grinder. You're an artist though. Your lines look great. I'm sure you'll have a few guys clamoring for you to do one for them. Oh look! There's one now!!!
Bill
Old Nov 12, 2007 | 01:55 AM
redbrd's Avatar
ORIGINAL: bryant
The side pods with lights appear to be a new addition as well. If I remember right Brian had to fab his own for indicator lights.
They are on there web site, just don't let them tell you there aluminum mount works with the dashboard it wont.
i got one because the salesman said it will fit.
but when i called to complain they where great, thay credited the $50 to my credit card and told me to keep the mount,
she said maybe i could sell it on EBay,
Old Nov 12, 2007 | 01:59 AM
redbrd's Avatar
I thought that might have been how you did it. That, or by using a small diameter Scotch brite disc on a die grinder. You're an artist though. Your lines look great. I'm sure you'll have a few guys clamoring for you to do one for them. Oh look! There's one now!!!
Bill
Thanks Bill, i did think twice about putting the pics on for that reason...lol
Old Nov 12, 2007 | 02:02 AM
green242's Avatar
hahaha
Old Nov 12, 2007 | 05:13 AM
tremor38's Avatar
Nice work! With that addition, the whole bike is crying-out even louder for headlight/shrould though
