Valve Adjustment Longevity
Old Aug 27, 2019 | 12:31 AM
Originally Posted by Kaw-Liga
I have reused similar gaskets many times on my Concours and VFR. But with the KLX when I try to fit the gasket into the grooves on the cover I can get one side done but then the corners do not line up. If I stretch it to make it fit one end it pops out the other end. I
I believe some folks with the '09 models had out of spec valve cover gaskets. They basically shrunk, making re-use very difficult. I'm sure others can confirm. This problem was corrected, and I believe all those in stock parts from Kaw are correct. This was only on production bikes for that year if I remember correctly.
Old Aug 27, 2019 | 10:10 AM
I avoided gasket issues by putting the cam cover back on when not working with the valves, like when I ordered shims. I pulled the cams out, put the cam cap back on snug, but not tight, then put the cover back on. It keeps the gasket in place without chance of shrinking. A bit of extra work, but no problem.
Old Aug 27, 2019 | 12:57 PM
Kaw-Liga's Avatar
Thanks for the info and tips
Old Aug 27, 2019 | 05:19 PM
oldgypsy's Avatar
That was my experience with my '09. Did the 600 mile valve adjustment, and could not get the valve cover gasket to seat correctly. Replaced the gasket and had no problem then, or with subsequent removal and re-assembly.
Old Aug 29, 2019 | 12:09 AM
KLX_boy's Avatar
I just had my 2012 KLX250 in for a valve adjustment a few days ago and after 14,000 miles was still perfectly in spec.
MattyTracks
Jun 14, 2015 04:06 PM
tjw24
May 29, 2013 10:01 AM
Apr 4, 2013 12:09 AM
birdmove
Feb 15, 2012 01:49 PM
yorgomiami
Ninja ZX-1100R
Oct 6, 2009 04:00 AM
