Valve Adjust @ 3200miles
Excellent writeup. I've done this job 3 times on other bikes and NEVER thought of that tie wrap idea. Though Suzuki marks their cams well. Anyways, I'm printin' this out, throwing all the torque specs on it, and adding it as 'supplement number 2' .......
ORIGINAL: a16tony
Nice write up Brian. Our 'before' reading couldn't be much closer. LOL I still wonder why the sprocket side valves were tighter?
I wonder how the factory build determines shim size? Do you really think they build the bike up with a standard shim size, then measure the clearances, and then take it apart again to put in the correct size for each valve? Somehow I doubt it - that would take too long and be too labor intensive. I'm guessing they maybe spot check one engine off the line, check its clearences, then set the next N engines that come off to that engine's shim size with the reasoning that all the engines built near each other in time will have similar specs. After N engines pass by, pull another one off and check it, and so on.
I'm just guessing here, I have no direct knowledge or experience on how the factories assemble these bikes. I just figure they are making a ton of these and whatever method has to be fast. Checking each one individually would not be fast.
This is yet another reason to do a valve clearence check early - the factory installed shims might not be optimal. After the first one valve check / adjustment, then you can probably go the 7500 listed in the manual until the next one.
ORIGINAL: rkutzner
Interesting on the factory shims. I wonder if they premeasure valve lengths or something like that and pick a shim that will work with all. There is no doubt they have some quick way of doing it, might be a special tool that mounts to the cam bearing cap holes and measures down to the top of the valve. With the expectation that the cam tolerances are a whole lot tighter, they could make a fair guess from there, maybe just picking a size that works for all.
As an example, last year I put 4.88 ring and pinions gears in my Jeep's axles. Took 12 iterations to get the front to pass the gear pattern and backlash tests. 7 in the rear. I doubt I could ever get it under 3 or 4 tries without luck. Anyways, at the factory, they have a tool that sits into the tubes at the bearing point and measures the pinion depth. At that point, they can look at measurement numbers stamped on each pinion and ring, make a measurement of the carrier and get the pinion and carrier shims right the first time every time. The tool cost more than the gears so I didn't buy it, but over the years I may regret that as I do buddies gears or maybe even the wifes 5.0.
It would be interesting to have a factory worker on the forum, we learn alot on the Jeep forums from those folks
ORIGINAL: rkutzner
Excellent Stuff and photos. Thanks heaps. I haven't done mine yet but having done a ZX6, I would highly recommend using a strong magnet to lift the bucket as it lifts the shim with it as well ensuring that it doesn't fall into the motor.
Wayne
Wayne
I second that! The last thing I think any of us want to experience is "wiggle..wiggle..CLUNK!
ORIGINAL: waynus
Wayne
Wayne
