Two out of three bikes down; riding KLX to work!
Went from a 75 road/ 25 dirt tire to a d606 set, plenty of wobble. It was on a 03 KLX 400 that had no wobbles at 90+. After the new tires, wobble would start to get bad at 70 or 75. Awesome in the dirt though!
My 8 miles commuts involves about 4 miles of 70 mph freeway. I don't know if it is the d606 knobbies or something else but I definitely get the death wobble, or headshake above 70mph. Do you all think that the tire choice is what causes the wobble? Solid as a rock below say 65.
Anyone know if I can turn the Kenda around and get a few more miles out of her or is that a no-no?
I think I may try and adjust the suspension sometime. I've got everything in stock center locations.
Highbeam,
I'm in the Olympia area, noticed the South Sound location in your post. The wobble could be a number of things or combination of a few; aggressive D606, tire balance, tire pressure, stem bearings needing repack and adjustment, front fender catching air, suspension adjustments, loose hardware, etc. I am no suspension expert and usually just make small adjustments, recording as I go from the nominal settings and try to get an improvement. I suspect it is a combo of tire selection/balance/air turbulence from the front fender?? There's a lot of folks that ride the highways with the smaller supermoto front fenders on their D/S bikes.
CousinLarry
Jul 3, 2012 02:30 AM
