Two Brothers M7 on an Australia 2009 KLX 250S
Old Oct 7, 2010 | 08:04 AM
BassTeQ's Avatar
Default Two Brothers M7 on an Australia 2009 KLX 250S
Hi all,
With the good aussie dollar, I'm thinking of getting from the USA a Two Brothers M7 exhaust for my Aussie 2009 KLX 250S.
http://www.jcmotors.com/p-8911-two-b...50s-06-09.aspx
Can anyone confirm if this will slip on without any issues onto my bike.
Thanks!
Old Oct 7, 2010 | 08:26 AM
Arctra's Avatar
I'm sure WestOzKLX will confirm this, but the Aussie KLX has the KLX300R header pipe, so rather get that pipe: http://www.jcmotors.com/p-8913-two-b...00r-94-08.aspx
Old Oct 7, 2010 | 11:50 AM
WestOzKLX's Avatar
Yep! You need the one for the KLX300R as our bikes have the slightly longer header you get on the 300R..>>>>>http://www.jcmotors.com/p-8913-two-b...00r-94-08.aspx
Muzzy cheapest at $247 and FMF Powercore at $259. >>>>>http://www.jcmotors.com/s-10-dirt-bi...agesize=999999
Old Oct 7, 2010 | 11:13 PM
BassTeQ's Avatar
Thanks WestOzKLX!
Do you know the Db level of the M7 with the quiet insert, I don't want it too loud, I see the Q4 is 93 - 96dB which is perfect.
Cheers
Old Oct 7, 2010 | 11:24 PM
WestOzKLX's Avatar
Muzzy and M7 are loud ?? with the insert. Mine keeps the roos at a safe distance though. Powercore 4 will be about the same as the Q4 (heard one on a local bike.)
Get a Dynojet kit (part # 2206 for KLX300R) while you're at it.
Old Oct 8, 2010 | 02:17 AM
BassTeQ's Avatar
Hmm I'd still like to keep it at a semi legal level. Its a shame there are no dB levels on the two bros website about the M7
Don't need a Dynojet Kit, already have a Bill Blue TM33 carb on there :P
Cheers
Old Oct 8, 2010 | 02:24 AM
Arctra's Avatar
I have the FMF Powercore4 on my machine and when you twist the throttle she isn't quiet. I tolerate it though, as the power pay-off is worth it in my opinion.
Old Oct 8, 2010 | 02:31 AM
BassTeQ's Avatar
It says on the FMF website "Max Sound output 96dB; most models below 93dB"
That's quite acceptable.
Did you have any problems fitting your FMF? I saw some other threads where is doesn't match up to the stock heater pipe too well?
Cheers
Old Oct 8, 2010 | 02:41 AM
Arctra's Avatar
I must be honest, I didn't fit it myself... I got Lloyd Penn in Artarmon to do mine and he said it was a bit of a pain. You can see it in this thread: https://www.kawasakiforums.com/forum...1&postcount=22
But then again, if you take WestOzKLX's advice in post 34 of that thread (https://www.kawasakiforums.com/forum...4&postcount=34) and loosen the header pipe, it will all probably go a bit smoother with the fitting.
Old Oct 8, 2010 | 05:56 AM
barbz's Avatar
I have the muzzy for the 300R on my 09 AUS spec.
Its loud, not sure how loud but its loud.....but good
I purchased from JC motors along with the carbie kit for the 300, great to deal with.
Cheers
Paul
________
Arizona medical marijuana
