Turn signals (a different approach to avoiding breakage)
Old Aug 8, 2007 | 03:47 AM
sinkoman's Avatar
Default RE: Turn signals (a different approach to avoiding breakage)
ORIGINAL: JB1
I put the flexible rubber mount extensions on mine, now they will fold right back without breaking
I was thinking about doing that. Should be as simple as just cutting the stem in half and using a small piece of nylon hose to connect them two pieces back together.
But I figured that a strong enough impact could still crack the plastic lense :\
Old Aug 8, 2007 | 05:08 AM
stellar_d's Avatar
ORIGINAL: deej
Yea I have the Acerbis with the turns, and I'm going to try to get them to be brighter, and the rear flush mounts are awesome, along with getting rid of the plate holder that hangs way down.
Thats what I have (it was you I copied actually ) although the license plate mount i have is a little different and the light is too high for the rack to still stay on. Might have to dosome chopping to get it on there. Deej do your lights flash alot quicker now that you have that setup? And do share when you figure out a way to get brighter lights
Old Aug 8, 2007 | 05:41 AM
If you are getting a fast flash, you need to install what I did, its a relay that plugs right in where the old one goes behind the headlight, and it not only fixes the fast flash, but it allows you with the cancel button to choose one of five different flashes including the stock normal flash. Let me see if I can find that post.
Well I found the post, but the link is dead now. This is the one I bought, but I can't find it in the states. That one is in the UK.
http://www.4-motorcycles.co.uk/acata...r_Relays_.html
Here you go, but I only paid around $24.00
http://store.58cycle.com/product_p/trick%20flasher.htm
Here is a site where you can click to see the 5 different flashes
http://xdcycle.com/store/pages.php?pageid=7
There are several other companies that carry similar products.
Old Aug 8, 2007 | 06:07 AM
stellar_d's Avatar
very nifty gadget indeed. might have to get something like that. although i dont remember clipping off the old relay. I cut the wires right at the bulb, inside the rubber stem.
joelcool64
Sep 28, 2011 02:09 PM
Buzz363
Jul 8, 2007 06:29 AM
Remo
Oct 17, 2005 11:30 PM
raychizel
Jun 27, 2005 12:27 AM
peerpressure23
May 19, 2005 05:32 AM
