Tubes loosing air.
When I was looking at new tubes I ran into some that had a warning that perfectly good inner tubes loose air. Some loose a fairly significant amount like 3 lbs a week. I never realized that inner tubes were air permeable. I guess some are and some aren't.
Any thoughts or recommendations on inner tubes that DON'T loose air? |
All tires lose air over time...even tubeless ones.
Nothing to worry about. Just check `em each time you ride. It's all part of T_CLOCS T-CLOCS ITEM WHAT TO CHECK WHAT TO LOOK FOR CHECK-OFF T-TIRES & WHEELS Tires Condition Tread depth, wear, weathering, evenly seated, bulges, embedded objects. Front Rear Air Pressure Check when cold, adjust to load. Front Rear Wheels Spokes Bent, broken, missing, tension, check at top of wheel: “ring”= OK — “thud”= loose spoke Front Rear Cast Cracks, dents. Front Rear Rims Out of round/true = 5mm. Spin wheel, index against stationary pointer. Front Rear Bearings Grab top and bottom of tire and flex: No freeplay (click) between hub and axle, no growl when spinning. Front Rear Seals Cracked, cut or torn, excessive grease on outside, reddish-brown around outside. Front Rear Brakes Function Each brake alone keeps bike from rolling. Front Rear C-CONTROLS Levers and Pedal Condition Broken, bent, cracked, mounts tight, ball ends on handlebar levers, proper adjustment. Pivots Lubricated. Cables Condition Fraying, kinks, lubrication: ends and interior. Routing No interference or pulling at steering head, suspension, no sharp angles, wire supports in place. Hoses Condition Cuts, cracks, leaks, bulges, chafing, deterioration. Routing No interference or pulling at steering head, suspension, no sharp angles, hose supports in place. Throttle Operation Moves freely, snaps closed, no revving when handlebars are turned. L-LIGHTS Battery Condition Terminals; clean and tight, electrolyte level, held down securely. Vent Tube Not kinked, routed properly, not plugged. Headlamp Condition Cracks, reflector, mounting and adjustment system. Aim Height and right/left. Operation Hi beam/low beam operation. Tail lamp/brake lamp Condition Cracks, clean and tight. Operation Activates upon front brake/rear brake application. Turn signals Operation Flashes correctly. Front left Front right Rear left Rear right Mirrors Condition Cracks, clean, tight mounts and swivel joints. Aim Adjust when seated on bike. Lenses & Reflectors Condition Cracked, broken, securely mounted, excessive condensation. Wiring Condition Fraying, chafing, insulation. Routing Pinched, no interference or pulling at steering head or suspension, wire looms and ties in place, connectors tight, clean. O-OIL Levels Engine Oil Check warm on center stand on level ground, dipstick, sight glass. Hypoid Gear Oil, Shaft Drive Transmission, rear drive, shaft. Hydraulic Fluid Brakes, clutch, reservoir or sight glass. Coolant Reservoir and/or coolant recovery tank — check only when cool. Fuel Tank or gauge. Leaks Engine Oil Gaskets, housings, seals. Hypoid Gear Oil, Shaft Drive Gaskets, seals, breathers. Hydraulic Fluid Hoses, master cylinders, calipers. Coolant Radiator, hoses, tanks, fittings, pipes. Fuel Lines, fuel valve, carbs. C-CHASSIS Frame Condition Cracks at gussets, accessory mounts, look for paint lifting. Steering-Head Bear- ings No detent or tight spots through full travel, raise front wheel, check for play by pulling/pushing forks. Swingarm Bushings/ Bearings Raise rear wheel, check for play by pushing/pulling swingarm. Suspension Front Forks Smooth travel, equal air pressure/damping, anti-dive settings. Left Right Rear Shock(s) Smooth travel, equal pre-load/air pressure/damping settings, linkage moves freely and is lubricated. Left Right Chain or Belt Tension Check at tightest point. Lubrication Side plates when hot. Note: do not lubricate belts. Sprockets Teeth not hooked, securely mounted Fasteners Threaded Tight, missing bolts, nuts. Clips Broken, missing. Cotter Pins Broken, missing. S-STANDS Center stand Condition Cracks, bent. Retention Springs in place, tension to hold position. Side stand Condition Cracks, bent (safety cut-out switch or pad equipped). Retention Springs in place, tension to hold position |
Before anyone asks - Yes. I do that. Each Ride. It takes far less time to perform (once you train yourself what to look for) than it does to wait for the pal with a Truck to haul your broken down ass home.
All inner tubes lose air, all inner tubes lose nitrogen a lot slower then they lose air.
The following is off a website "For passenger car applications the main claims seem to be Reduced corrosion – because unlike air there's no moisture in pure nitrogen Slower rate of pressure loss – because nitrogen molecules are larger than oxygen molecules (which make up 21% of compressed air) Leakage can occur through the tyre's inner liner but can also occur through the valve, punctures, or failure of the seal between tyre and wheel rim. Pure nitrogen might leak more slowly through the liner, but regular checks of tyre condition and pressures will still be essential. Corrosion of the tyre through use of normal compressed air alone is most unlikely because only the outer tread band of a car tyre contains steel – the amount of moisture reaching it from the inside is minimal. Changing to nitrogen involves removing all the air which is already in the tyres and then re-inflating them with purified compressed nitrogen. There will be a one-off charge per tyre but once filled with nitrogen any future top-ups would also have to be with nitrogen if any advantages are to be maintained." I know the steel belts don't apply to bike tyres but the rest does |
natural flatulance
Originally Posted by horizonod
(Post 350340)
Any thoughts or recommendations on inner tubes that DON'T loose air? no such thing as a tube that doesn't lose air if you don't want to loose air use solid rubber,been proven over the last 100+years it dont F'N work |
Ride you bike, worry about yer problems later, best teacher.
And at the joy of an klx forum fisticuffs,hop yer arse on a klx spend 20 grand plus on a bmw that you cannot pickup, yes I' am well maybe not angry a tad perturbed
And don't forget that ambient air temperature affects the air pressure. You could see a few pounds fluctuation in air pressure based on a fluctuation in air temperatures. If the temperature falls 40 degrees, the air pressure is going to slip a bit. You didn't neccessarily lose air, but you lost the pressure.
And I thank God lost a wife, own a beach , basketball, soccer ball. Same principals and theory's apply.
cavaties holding air
(Post 350340)
