Trailtech Vapor users
Old Dec 8, 2006 | 02:44 PM
markturbo's Avatar
Default Trailtech Vapor users
Do you have a picture of the unit lit up at night? And did you run into any problems with the sensor while going thru mud, does it stay secruly mounted and keep it's reading?
Thanks
Old Dec 8, 2006 | 09:44 PM
jeepphamilee's Avatar
Default RE: Trailtech Vapor users
No problems at all since I got it and it has been used quite a bit. The security of the mounting depends entirely on how YOU mount it. The hardware you get with the unit is crap (IMHO) I made my own mount and it is VERY secure. These picture are a couple thousand ago, but it looks the same now as it did them.
Old Dec 8, 2006 | 10:18 PM
markturbo's Avatar
Sweet! Looks great!
You made the holder that the Vapor is sitting in?
Old Dec 8, 2006 | 11:45 PM
YYY.GUY's Avatar
Nice job! [sm=smiley20.gif]
Old Dec 9, 2006 | 03:19 AM
KAWASAKIspeed's Avatar
that thing looks pretty good. i am thinking of maybe getting one. can you show pictures of it idling. that would be cool. good luck.
Old Dec 9, 2006 | 03:25 AM
MarkTurbo, i bought the aluminum case and modified it so the little LEDs would fit and I made the black bracket underneath it out of a old piece of 2X6 rectangle tubing cut to fit.
Kawi-speed, i will try to get some idle picks, but she is all tucked in for the night.
Old Jan 30, 2007 | 04:57 PM
mooredan's Avatar
Jeep,
What was the P/N for the aluminum case? I'm checking on trailtech's website, but don't see the case which looks similar to yours. Thanks.
Dan
Old Jan 30, 2007 | 05:26 PM
TeamKLX250's Avatar
I have the 022-TM which looks similar to Jeeps but there is a few that look similar
http://www.trailtech.net/vapor_protectors.htm
Old Jan 30, 2007 | 07:05 PM
ORIGINAL: TeamKLX250
Thats the one. Note that you can't actually use the holes in the case for mounting, they don't line up everything right. I lopped them off a bit and drilled some little holes for 1/4 leds.
Old Jan 30, 2007 | 08:03 PM
Ziguy's Avatar
At $99, does it come with the engine temperature sensor? In the instruction, they say that Engine Temperature readings require optional sensor.
