Torque wrench question
Old Aug 18, 2008 | 05:08 PM
+1 kawi
Old Aug 18, 2008 | 08:34 PM
je2000's Avatar
I agree though. A 3/8" drive wrench has plenty range for this application and you can step it down to 1/4". I'm not sure the 1/2" wrench will go low enough for most bike applications. What is the lowest range on your 1/2' je2000? Realistically it should go as low as 5 Nm for most applications on this bike (KLX250.)
What's stupid is that I made the trip all the way downtown on bike, and forgot the backpack. So I bought a backpack to take the wrench home in. It didn't look that big on the internet!
It goes from 0-200 in 5 nm increments. I dunno, I may just return it and get the 3/8" one.
This is what I get for buying a crappy walmart socket set in the first place!
I'll try the adapter and see how it does.
Old Aug 18, 2008 | 08:36 PM
gerrynolan's Avatar
Those 1/2" torque wrenches are pretty inaccurate below 30 Lbs. Many don't read below 30. I would get a nice 3/8". Make sure you carefully hold the rear axle bolt from turning while torquing the nut. If not, You'll booger up the "snails"(Chain adjusters)
Old Aug 18, 2008 | 08:43 PM
je2000's Avatar
What's the general range on common maintenance bolts for lbs? This one goes all the way to zero. I'd say it'd be reliable accurate in 2.5 to 5 lb increments.
Old Aug 18, 2008 | 08:49 PM
gerrynolan's Avatar
I believe most of them are below 10 Lbs.
Old Aug 19, 2008 | 06:19 AM
WestOzKLX's Avatar
This is the info' you need.
Old Aug 19, 2008 | 02:16 PM
je2000's Avatar
If this forum had a rep system, I'd give you some for this post! Where'd you find this? This confirms I bought the right wrench.
The list should be stickied. The noob sticky needs to be fixed it's all screwed up.
THANK YOU!!
Old Aug 19, 2008 | 02:52 PM
WestOzKLX's Avatar
It's in the manual. I posted a free version (Pdf) on here last week.
If you ask someone may email one to you.
Old Aug 19, 2008 | 02:56 PM
gerrynolan's Avatar
Just remember that the smaller bolts are in "inch pounds". Just use common sense. All the little 8 & 10mm bolts are way too small to use a big 1/2" torque wrench IMO. I just use a 1/4" ratchet on the little bolts and "hand torque" them. Worked at a Honda dealer for 5 years and only used Torque wrench for head gaskets, Bearing caps & a few other rare cases. I've seen too many people set their 1/2" torque wrench to 80 something & snap a 10 millimeter bolt off that was supposed to be in in-lb not ft-lb. I realize this is common knowledge for any technician but we have many people that are just starting out with mechanical maintenance.
Old Aug 19, 2008 | 05:31 PM
WestOzKLX's Avatar
Nm.
