Torque specs question.
Chris you can buy only the shims you need.... like he said they are like 11-12$ a piece.... or the kit, so you know you will have everything you need.
Valve clearance :
Intake: 0.10-0.19 mm
exhaust: 0.15-0.24mm
cylinder head cover bolts:
7.8Nm (0.8kg-m, 69 in/lbs)
if you adjust them, the camshaft cap bolt torque is : 12n-m (1.2kg-m, 8.5 in/lbs)
I think thats all you would need.
(just happen to have the service manual right here)
Fyi, 12n-m = 106in-lb not 8.5.
