Torque specs
Old 06-11-2008, 02:28 AM
Tim1's Avatar
Default Torque specs
Does any one have the torque specs for the rear wheel nut & the rear sprocket screws?
I think there was a posting with all of the torque specs, but I can't seem to find it.
Tim1
Old 06-11-2008, 03:23 AM
Default RE: Torque specs
I used a torque wrench the first time I changed it, after that I just wrench it on tight but loose enough so I can get it off with my trail tire tools and don't forget the cotter pin.
Manual says 72 ft-lb rear axle nut
Front Axle nut 65 ft-lb
Front Clamp nuts 87 in-lb.....careful with these they are easy to breakoff.
Old 06-11-2008, 03:25 AM
Opps didn't see rear sprocket nuts... 22 ft-lb
Old 06-12-2008, 06:10 AM
MaverickAus's Avatar
yes thats 87 INCH / pounds for the front, they are very easy to break. I replaced my broken ones with exhaust studs, they work just fine
Ginsu4u
03-09-2018 01:39 PM
ReaperFox
07-23-2006 08:17 AM
Neuby Wan Kaneuby
05-27-2006 07:39 AM
rkutzner
04-23-2006 02:34 PM
thecount
03-13-2006 07:14 AM
Quick Reply: Torque specs
