torque specs?
Old Oct 8, 2007 | 05:05 PM
mudjunkie's Avatar
Default torque specs?
I am about to do the swingarm and pivot arm bearings and was writing down the torque specs that nobrakes posted, however there are a few missing..the swingarm specs are there but none for the pivot arm..I assume the lower and upper dogbone bolts are torqued the same? 60- ft-lbs, but the ones I do not know are the lower shock bolt and the pivot arm to main frame bolt. Any help would be greatly appreciated...also..is there a post containing just torque specs that I am unaware of? (if so, sorry for starting a new thread) but perhaps we can have one if there is not. Thanks again
Old Oct 8, 2007 | 10:20 PM
kgwld1's Avatar
Default RE: torque specs?
Rear shock mount nuts
29 lbs.
Tie rod mounting nut
60 lbs.
Rocker arm pivot nut
72 lbs.
Kevin
Old Oct 8, 2007 | 10:35 PM
Here you go, click for full size.
Old Oct 8, 2007 | 11:04 PM
mudjunkie's Avatar
awesome...thx a million guys.
Ginsu4u
Mar 9, 2018 01:39 PM
ReaperFox
Jul 23, 2006 08:17 AM
Neuby Wan Kaneuby
May 27, 2006 07:39 AM
rkutzner
Apr 23, 2006 02:34 PM
thecount
Mar 13, 2006 07:14 AM
