Today's Project (Wheel Stand)
Old Dec 2, 2007 | 06:43 PM
bryantjt's Avatar
Default Today's Project (Wheel Stand)
Hey gang, since I need to straighten my wheels and its the start of the North East winter (16F and snowing) I decided to build a stand so I could work on the wheels in the house. Materials required were ~31' of 2x4's, box of screws, 1: 2'long 1/2" threaded rod, and 1: 2' long 3/4" threaded rod with matching nuts and washers. It took me around 2 hrs or so to build, its a bit overbuilt but I wanted it to be stable while working on the wheels with a dial indicator. I'll attach the plans below, the only thing I did differently while building it was open the 10" dimension to 13" to be sure I could fit both wheels in at the same time. I did this because it will also serve as a storage rack for my spare set of wheels (I have street tires and dirt tires). I drew it up in Autocad and can modify it for anyone that wants it slightly different if you are interested in it.
Sorry for it being so fuzzy, I had to export as a .bmp, then convert to a .jpg to keep the file size low.
Old Dec 2, 2007 | 06:45 PM
Default RE: Today's Project (Wheel Stand)
You crazy engineer you.Looks nice.
Old Dec 2, 2007 | 07:01 PM
bryantjt's Avatar
Seems to be and was only $30 for materials.
Old Dec 2, 2007 | 07:04 PM
Looks nice. I used a drill rod on two V blocks.
Old Dec 2, 2007 | 07:45 PM
OMalley912's Avatar
Now that's solid and sturdy, looks good.
Old Dec 2, 2007 | 09:04 PM
klx250s_rider's Avatar
Excellent looking piece of work! The only mods I would need would be for my girlfriend - if would need leather leg and wrist restraints and...
Old Dec 3, 2007 | 02:29 AM
4SEVEN3's Avatar
ORIGINAL: klx250s_rider
Worthless without pics!
J/K............unless!
Old Dec 3, 2007 | 02:58 AM
loudoo76's Avatar
looks great, but it needs some green paint
Old Dec 3, 2007 | 03:08 AM
bryantjt's Avatar
True but I don't have Kawi green and forest green just wouldn't cut it.
Old Dec 3, 2007 | 03:45 AM
Sweet stand, Josh! You going to try your hand at lacing up a wheel maybe?
