tm accelerator pump
Old Sep 28, 2010 | 05:34 AM
ol guy's Avatar
Default tm accelerator pump
Can anyone direct me to the tm accelerator linkage thread that showed how to shim the rod to get a smaller shot of fuel .
Old Sep 28, 2010 | 05:52 AM
FlyingFinn's Avatar
What carb, TM33 or TM36?
Old Sep 28, 2010 | 05:52 PM
ol guy's Avatar
Tm 33
Old Sep 28, 2010 | 06:04 PM
FlyingFinn's Avatar
With TM33 the popular mod is to shorten the AP rod by about 0.15" to make it ~2.7" long. That, supposedly changes the AP timing to better suit the KLX.
Probably even more important thing is to make sure the AP nozzle is adjust just right so that the fuel spray hits the needle right above the jet needle opening.
That 'splashes" the extra fuel around and helps getting it vaporized and into the cylinder when it's need.
Mikko
Old Sep 29, 2010 | 05:03 AM
slippery750's Avatar
Mikko
Ok I need more info on this one! How do you adjust the nozzle, is;nt it just a pressed in brass piece? I have noticed sometimes when I go full throttle fast the bike just does not like all that at once. Could be a slight jetting issue though.
Old Sep 29, 2010 | 05:37 AM
FlyingFinn's Avatar
It's not pressed in, it's mainly held in place by tight rubber grommet and can be easily turned after you remove the float bowl.
Sometimes they do get little stuck though, don't destroy it if it's stuck.
The bottom end of the nozzle (the end that seals against the fuel passage in the bowl) has a slot on it like a screw so you can turn it with a screw driver.
Mikko
Old Sep 29, 2010 | 06:45 PM
GreenMonsta's Avatar
Use Needle nose to turn the piece sticking into the carb body. No need to remove the bowl. I've done it it's only held in by an o-ring. Hook up the fuel and hit the throttle to see if it bounces off the needle. Adjust as needed. Wear glasses fuel in the eye hurts like hell.
falcn
Aug 9, 2014 07:21 AM
Pogiboy
Jul 6, 2012 03:10 PM
albany551
Nov 20, 2009 01:36 PM
BVOYTEKB
Apr 25, 2007 05:06 AM
