tire rubing
Old 05-01-2009, 03:21 PM
al.b's Avatar
Default tire rubing
hi guys
i need some suspension help. i lowered the rear with longer dog bones about
1 1/2 in,and the front about the same. i just put a new k-760/120/100-18
on the rear, hooks up great in the sand and soft dirt. i went out yesterday
a long run of sand to get to the verry tight single track. lots of woops,hills
logs now it starts to sound funny. wierd scuffing sounds, i thought i might
have picked up a tree branch or something. stop to look , nothing , on again
same thing i can here it over the q-4. looked again and i find tire rub marks
9in up the green inner fender to the rivets??. anybody have this problem??.
i weight in at 156 so i dont think im to heavy for it??. any tips tricks,
something i can try a $1000 shock is not an option right now. i might half
to go back to the stock bones for now,until i get this sorted out.
any tips would be great.
ps i made my own t handle for the fuel/air screw no more compleat teardown
to adjust it. i tried to put some pic's up on the group album but it wont
take the pasword? cant get in.
thanks
al.b
Old 05-01-2009, 03:25 PM
Dang....I weigh 230 and was as high as 260 and I have never had a tire rub. Have you adjusted the rear spring and the other adjustments on the suspension? It really helps...although re-springing is what really needs to be done. So I'm told.
Old 05-01-2009, 03:29 PM
finzel's Avatar
Default rubing
a 100+100 18 tire will take care of it.
Old 05-01-2009, 04:30 PM
LearjetMinako's Avatar
Two things that you did to cause it. 1. Lowered the suspension. 2. Bigger tire than stock. The stock tire is about a 120/90-18, 100/100-18, or 4.60-18. Best suggestion to fix the problem is to get a stiffer rear spring. Or a cheaper (freebie) by-pass solution is to increase the damper setting.
Old 05-01-2009, 04:49 PM
+1 on the 100/100/18,, that what mine was stock,, I beilive the older ones were 120s but i like the 100 just fine
Old 05-01-2009, 07:58 PM
RaceGass's Avatar
The problem with longer links is that the whole arc of travel in your suspension has been moved the same amount. If you lowered the bike 1 1/2" your bottoming out point has been raised up in the rear fender area the same amount. Travel limiting spacers in the shock are the correct way to lower your bike without the problems you are having.
Old 05-02-2009, 01:15 PM
al.b's Avatar
Default rub
i spent yesterday tearing the hole *** end apart,right down to the
swingarm and cleaned all the bearings regreaseed everything,man did it need
it. a little rust on the tubes that run in the needle bearings,cleaned them
up with a fine scotchbrite pad. i put it all back together with the oem bones.
got it off the stand [crap] the kick stand is 1 1/2 in to short. i forgot how
tall it was,now i'm tippy toeing . half to get a new stand. wear would i
find travel limiting spacers,do i need to rebuild the shock ? .now back to
stock height its a little wierd to be back up in the air.
thanks
al.b
Old 05-02-2009, 11:03 PM
RaceGass's Avatar
The shock will have to be torn down to install the travel limiting spacer, so its a good time to rebuild it at the same time. Call the shock rebuilders that are closest to you to find out if they can lower your bike the amount you want.
Old 05-03-2009, 12:16 PM
al.b's Avatar
thanks racegass
i'l look up a few shops around here and see what i can find.
i know of a supermoto guy,he might be able to help.
thanks again.
al.b
Old 05-03-2009, 12:30 PM
MaverickAus's Avatar
Which links did you buy? I bought 2 different sets and this is what I thought of them https://www.kawasakiforums.com/forum...ad.php?t=10267
Quick Reply: tire rubing
